Question about Staples Office Equipment & Supplies
I haver a staples dal-txc18a which runs continuously when turned on
I have tried to reload the stapler but it will NOT staple What am I doing wrong?
1. Make sure you have the correct staples for the machine. This machine requires "standard" staples, which are 1/4" staples.
2. Check the staple cartridge to make sure there are no visible jams.
3. Check the power connection to the stapler. Is it plugged in? Is the plug working?
4. If you continue to experience problems, contact the manufacturer at
1-800-STAPLES. They will replace the stapler if it continues to malfunction.
Apr 18, 2011 | Staples One Touch High Capacity Stapler
I can't seem to reload staples into this stapler. I used the staples that came with it and it worked fine. I try reloading and it doesn't staple.
With the stapler sitting a solid surface, turn it 180 degrees so it is pointed away from you, and you are looking at the back. Press down on the plastic extension that you see (about mid-height on the stapler). This releases the staple-holding compartment (it shoots out the front of the stapler). Reload it with standard staples, push the compartment back in place until you hear a click. Voila!
Apr 15, 2011 | Staples One-Touch DX-3 Desktop Flat Stack...
Runs continuous when turned on, but stops when paper is inserted
I owe this to a Steve-EE.
Mine was the LED where the paper feeds. $1.69 for a 2 pack.
May 09, 2010 | Staples SPL1050LBRX (CrossCut) Shredder
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
