Question about Home
Can i put a wooden overlay on top of the electric blanket or should it go under the electric blanket?
Can electrical cord for electrical blankets go between mattress and box spring
Wires should be on the floor. Do not put them where you may lay on them and or cause friction on them (even if it's just rolling over during the night).
Sep 19, 2014 | Sunbeam Twin Electric Auto Heated Blanket-...
Why the touchpad wont switch from water to ice gi5svaxq01
The overlay is a very thin keyboard and it is possible that it has been damaged. The keyboard for your model is=> W10315983 Overlay. It is also possible that you have a bad connection where the wires attach to the overlay keyboard or where the wires connect with the rest of the refrigerator at the top left hinge under a hinge cover. Also possible is the dispenser low voltage keyboard=> W10162500 Main Control Board Do you have a Electrical Test Meter? If you would like I can walk you through the diagnostic's to see what is going on. I am here should you have questions, Thanks John Tripp Appliance 911
A parts manual can be found Here
Jun 10, 2014 | Refrigerators
Sunbeam electric blanket repair waynesboro ms
wash the blanket then throw it in the bin
water and electrical components do not mix
electrical blankets are just a resistor element in ceramic covering and if you put that in a washing machine that is the end of the insulation
Mar 18, 2017 | Sunbeam California King Arlington Heated...
Electric blanket stopped working
Its an electric blanket. All electric blankets are made cheaply and many do not adhere to even the most basic electrical standards. No one with any sense will touch it or try to repair it. It might make a good lap warmer if you take off the plug and seal the hole. Now go and buy a really good new one- (not at one of those mega stores where folks take humorous cellphone snapshots of the shoppers who enter the places and then put them on a Facebook post like "...market shoppers". I've gone British and bought nice comforters and put on English flannel sheets and pillow cases. (Once you go flannel, even for summer, you'll never go back. and flannel wears like iron). Happy snuggling.
Mar 18, 2013 | Furniture
I bought a queen dual control warming blanket . I barely used it the first time I bought it a year ago. I put it into my closet for storage after the first winter. I put it on the bed today getting ready...
The flashing lights usually means theres a problem and the blanket has shut itself off so it wont cause a problem...Like burn down your house.
I love electric blankets but I have had little luck with them. Its only a matter of time before they get like this. I have never gotten one to work again after it has started to blink.
If you still have the box maybe there is a warranty.
Sep 21, 2011 | Health & Beauty
When i open the game i have massge error during Bable initialistion
Instructions
Things You'll Need:
* Electrical tape
* Wooden dowel
* String
1. Place a strip of electrical tape over the latch of the dryer. If your dryer loads from the front, simply locate the latch and place a strip of electrical tape over it. This will stop the door from "catching."
2. Put a wooden dowel on the base of your top loading dryer and prop open the top, the same way you open the hood of your car. This will keep the dryer door open quite easily.
3. Tie a piece of string to the knob on the dryer door. Then tie the other end of the string to something else sturdy in your laundry room. Make sure the string is taut. This will also keep your dryer door open.
Feb 22, 2011 | Dryers
Replace clock timer
ok bobo lets go....always unplug unit first...pull the range from the wall,,,best if you get behind it if you can,,,now you those 8 phillips head screws around the top back of console..remove that bact console panel...now there 4 screws holding the clock in remove screws but not the wires..let the old board just hang from wires,,your close now ...put new board in there did you get the overlay with the new board ,,no..so take that flim strip overlay of the old one,,ok mount the new clock put back for screws,,,take the old clock timer connection off one by one and put on new clock ,,...you did it,,,just reverse to put together,,,
Dec 29, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Electric oven range not working
common replace eoc clock get eoc and overlay the black or white cover for the clock is the overlay if you peel the old one off carefully you can restick it on the new eoc pull the range out and remove the 1/4 inch screws from around the top panel after un plugging the range remove the top panal face the front of the range right under the clock remove the two 1/4 in screws go to the back of the range and pull the eoc bracket backwards from the bottom and out take the four screws out that hold the eoc to the bracket turn the eoc sideways and out of the bracket and let it hang screwthe new eoc to the bracket with the two srew holes at the bottom put the overlay on the new eoc and put the top of the bracket in first then push the bottom in making sure the holes in the bottom line up with the holes on the cotrol panael go to the front and replace the two screws then go to the back and with a small screwdriver gently pry the wires off the old eoc and place them on the new one if you get lost theres letters on the wires that match the ones on the eoc replace the back panel plug it in reset the eoc clock all done make shure you get the complete mod# when you order the eoc its on a plate on the left side of the range body when you open the bottom drawer all done
Dec 22, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
