Question about Cameras
What memory card is required - Cameras
  • Cameras Master
  • 5,412 Answers
For what equipment ?
Posted on May 14, 2017
Memory card will not format
If other memory cards take the format then your card is fubar.
Aug 25, 2017 | Kodak EasyShare M863 Digital Camera
My memory card is not working
Memory cards, also called memory sticks or MS cards, can create problems with a computer. Sometimes, a computer will not read the card or errors cause problems when removing files from the card to put them onto the computer.
Problems range from a virus on the memory card to inappropriate software on the computer. Fixing the problem partly depends on the cause of the problem, but making the card work is simple and takes only a few minutes.
Scan for viruses. Some viruses or worms infect MS cards.
A computer that suspects a virus might interfere with the memory card as a result.
Look for viruses or problems with the anti-virus software that won't allow the memory card to open. If a virus if found, remove the virus through the anti-virus software before opening the memory card.
Check that the computer has the appropriate software installed to read the card.
Some MS cards or memory sticks might require more updated software or specific software that is not on the computer.
If the software is installed, look for current updates and download any updates to determine if the problem is old software.
Open the control panel.
Click on "Add New Hardware" and see if it is available.
If the hardware for the memory card is not installed on the computer, this will allow installation.
Once installed, the card should read.
If the memory card is not showing up, the problem is often damage to the card, which prevents reading the card. If the card is damaged, it must be replaced.
Use an adapter.
Some memory cards are not designed for reading in a computer directly and require the appropriate adapter.
The adapter changes the data to the appropriate system for the computer to read it.
Hope this helps
Nov 16, 2012 | Electronics - Others
I keep getting a card error and I have tried 9 dif cards including a new one and still the same thing.
Welcome to FixYa.
Getting a card error means that:
* memory card is not yet formatted for camera use
* memory card requires cleaning
* using a incompatible memory card
* camera malfunction
All you need to do is:
Memory Card not formatted
You have to format the memory card. Some memory card can't be formatted using a PC's, or formatted by another digital camera. I suggest that you have to format the memory card using the camera itself.
Memory Card requires cleaning
Use a dry and soft cloth in cleaning the memory card and the memory acrd slot.
Using a clean pencil eraser can also be useful in cleaning the memory card but you have to be careful, slightly rub the eraser on the memory card.
Incompatible memory card
Please use a compatible memory card
Camera malfunction
In this case you have to contact you service center. It will be a big help if you can check if your camera is still under warranty to get a free service.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
Apr 11, 2011 | Cameras
Camera tells me "memory card requires formatting."
Your memory card is larger than 2GB, isn't it? The CX7330 works with MMC and SD cards. If your card is larger than 2GB then it's actually an SDHC card. While SDHC cards will fit into the camera, they are electronically incompatible and won't work in the CX7330.
Dec 20, 2010 | Kodak EasyShare CX7330 Digital Camera
What specific memory card is required?
Memory cards should be formatted before use. They should also be formatted each time you finish downloading pictures from it.
Jul 05, 2010 | Vivitar ViviCam 3720 Digital Camera
My Z740 won't format my memory card. When I turn
My Z740 won't format my memory card. When I turn it on - it says memory card needs formatted. I tell it to format - and it just repeats the Memory Card requires formatting message.
Aug 15, 2009 | Kodak EasyShare Z740 Digital Camera
When i turn the camera saids memory card requires formatting. then continues to say formatting will delete everything on memory card. i press continue and nothing happens. goes back to say memory...
Use a computer with memory card reader, and read the card using a computer.
If the computer says the same and does not read the card, then the pictures inside the card are usually lost.
If computer instead does read the card, then transfer all picture on computer using the memory card reader, and format the card using complete formatting.
If you need to use the camera tonight, then buy a spare memory card.
If the camera returns same error on different card, then you may have a faulty memory card slot, but that is quite uncommon.
Jun 18, 2009 | Kodak EasyShare C875 Digital Camera
Garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
Jan 26, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Error message - Memory card requires formating
Before suspecting the camera, I'd simply try another memory card in it. Memory cards can and do fail and often can behave inconsistently before they fail completely.
Jan 09, 2018 | Kodak EasyShare Z612 Digital Camera
i have kingston's memory card(micro sd) i have never set a password. first when the set is alright it doesn't requires the password to unlock the memor card for my set but in others set it requires the password.but when i have given my nokia 6300 to the nokia care center,now it requires a password which i have never set.But the other mmc which i got with my mobile is working alright.So,please suggest me a solution to unlock my mmc.
Jan 18, 2008 | Cell Phones
Cameras Logo
56 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
