Question about Miscellaneous
How can i login on my classroom
Login classrooms looking at your points sending things to your classroom
Ok well this is a USB camera, ya need the correct cable and the drivers.. Take a look here as there is a lot of info about it. But basically as I said, ya need to find the correct drivers and install the camera into any USB port, when it's detected give it the driver software and ya should be good to go. try the above link for some info.
Posted on Jul 30, 2007
  • 47 Answers
SOURCE: Function key to switch to a video projector
The Fn key + f4
This should toggle your video output.
Good Luck....dont forget to rate my response!!!
Posted on May 30, 2008
  • 150 Answers
SOURCE: my hitachi cpx201 projector says to check the air flow
Hi There Teacher!
the air filter unclips on the left hand side, lens facing out.
after vacumming out the filter see below for filter reset counter procedure
Good Luck!
Turn the projector on and reset the filter time using the FILTER TIME item in the EASY MENU. Before taking care of the air filter, make sure the power switch is off and the power cable is not plugged in, then allow the projector to cool sufficiently. Taking care of the air filter in a high temperature state of the projector could cause an electric shock, a burn or malfunction to the projector. Use only the air filter of the specified type. Do not use the projector without the air filter or the filter cover. It could result in a fire or malfunction to the projector. Clean the air filter periodically. If the air filter becomes clogged by dust or the like, internal temperatures rise and could cause a fire, a burn or malfunction to the projector. WARNING Please replace the air filter when it is damaged or too soiled. When you replace the projection lamp, please replace the air filter . An air filter of specified type will come together with a replacement lamp for this projector . Please reset the filter time only when you have cleaned or replaced the air filter, for a suitable indication about the air filter. The projector may display the message such as ?gCHECK THE AIR FLOW?h or turn off the projector, to prevent the internal heat level rising. NOTE (1) Press the MENU button to display a menu. (2) Point at the FILTER TIME using the ??/?? button, then press the button. A dialog will appear. (3) Press the ?? button to select RESET on the dialog. It performs resetting the filter time.
Posted on Jan 17, 2010
Testimonial: "Thank you very much! My projector is back on track. You saved me. My students and I are very happy!"
  • 1901 Answers
SOURCE: Classroom lost directions to Sorry game need one
If you are still in need, click this link for instructions:
Thanks for using Fixya.
"Sorry" it took so long to get an answer.
Posted on Jan 26, 2010
Testimonial: "Thank you. I had given up ever finding the directions. You have stopped many classroom arguments over this game."
  • 4 Answers
SOURCE: I have a Califone 1620 model economy classroom phonograph in need
Probably a bad relay switch. Open up the turntable. Identify the motor that spins the table. Follow the wires of that motor to, perhaps, some type of little circuit board with a relay. I have a Backley-Cardy 322-487 classroom phonograph which uses a Califone 1620 amp and a BSR turntable. To get the table to spin, you have to move the tone arm. Mine doesn't move and I'm in the process of replacing the faulty relay that is the problem.
Posted on May 14, 2010
Miscellaneous Logo
22 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
