Question about Dryers
Hello... after I dry a load of clothes the control panel will not turn back on. The dryer plays the normal musical tune when I hit the power button, but it does not light up and is unusable.
  • 412 Answers
Have you tried unplugging the dryer power, waiting a few seconds and plugging it back in? Just a hunch.
Posted on May 14, 2017
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
Jan 01, 2016 | Dryers
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
How do I dry clothes
Either hang them up wet or put in clothes dryer
Nov 26, 2014 | Malber WD1000 Front Load Washer/Dryer
My dryer was working just fine. it finished it cycle and shut off. took the clothes out and could not get the instrument panel to light up. ran my hands back and forward across the various buttons on the...
You may have a loose ground wire. Look under the control panel. Pull dryer out from wall and look on back sometime you may frin a ground wire ( green or white ). Good luck..
May 14, 2011 | Maytag MDE9700AYM Electric Dryer
The start button is flashing red and beeping and the drying cycle won't start. Help!
  • If the machine shakes or makes a lot of noise, make sure the dryer is level. Some shaking is normal, but it shouldn't bounce around like it's itching to go somewhere. Adjust the leveling legs. They just screw and unscrew. Check to make sure the load inside the dryer is properly distributed and is not all clumped together.
  • Match the control settings to the type of load, and make sure you're not overloading the dryer.
  • Check that the ducts aren't blocked if the clothes take too long to dry. Look for lint or missing socks. Check to make sure the ducting isn't kinked, and make sure the outside dryer vent flap moves freely and isn't blocked---by snow, for example.
  • Sort your clothes by weight if they aren't drying properly. Lightweight clothes should be dried separately from items like comforters.
  • Make sure the lint drawer is empty.
  • Press the "Stop" button or press the "Lock" button for three seconds if the controls don't work. Press the "Power" button to wake the dryer up if it won't start. Make sure the "Delay Start" button isn't flashing if the machine fails to start. Press "Start" again.
  • If you see only lights displayed on the screen and no numbers, it's normal. The dryer has detected a low level of moisture. Other normal behavior is when the time remaining jumps to a lower number---it's revising its estimated time remaining. When you can't make a selection and the dryer beeps twice, the dryness setting is incompatible with the chosen dry cycle hope this helps please tell me if it does
Dec 06, 2010 | Zanussi Dryers
When drying a load of clothes the dryer (Asko 7305) simply quit and when I came back to the unit the clothes were dry, but the digital panel was dark and no power available to the unit. I have pushed the...
Hello Susan, Welcome to FixYa. Have you checked to see if perhaps one or both of the fuses may have blown at the back of the unit...I don't mean the hi-limit that you already referred to...I mean the in-line fuses the Asko machines are equipped with. Let me know and we can move forward from here. Regards, Macmarkus :)
Sep 12, 2010 | Asko T761 Electric Dryer
GE front load dryer
Clothing gets caught in the front of the dryer as it spins. This is leaving black marks and wholes in our clothing.
Apr 06, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Control Locked
push and hold in far right button on conrtol panel( look closly you see control lock) hold for 3 secs and it will turn off
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
Top Dryers Experts
