Question about Graff Plumbing
I have a Graff bath ceramic faucet, Model Elegant 1250-S1, which is leaking. Can it be repaired?
  • 14 Answers
SOURCE: water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Posted on Jan 03, 2009
mrhotandcold
  • 248 Answers
SOURCE: 1 handle pull and turn bath room faucet no hot
a common fault if the handle is forced the spindles get worn best to replace
Posted on Sep 18, 2009
  • 129 Answers
SOURCE: bath tub water faucet leaks. It is a single
You will have to replace spring ang washers behinde valve cartridge.
Posted on Oct 24, 2009
SOURCE: Water leaking from top section of kitchen faucet
You might try replacing the o-rings but I would replace the cartridge and the o-rings. Be sure and use silicone lubricant on the o-rings.
Posted on Feb 26, 2010
agent91
  • 2100 Answers
SOURCE: My bath tub with jets hums and I can't find an access panel.
The pump is usually at the side/rear of the tub, opposite the drain, the faucets can be mounted anywhere, but usually over the drain. The panel could be tiled, and just grouted in, if it is not exposed, try tapping on it to see if it sounds different in spots. Who knows, it might just fall out. How about behind the back wall?? Closet? Access? There is no electrical parts in there to repair, Pretty sure it is just the motor. and a bunch of pipes glued together and stuck through the tub. Did you fill the tub with water before trying the jets? Just checking. Hope this helps.
Posted on May 27, 2010
Bathtub faucet leaking a lot
Change the gaskets.
Popular Grohe 3427 Concetto... Repair Questions - Fixya
www.fixya.com/support/p1162411-grohe_3427_concetto.../popular
Popular Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome questions, problems & fixes. Find expert solutions to common issues, DIY guides, repair ...
Grohe 3427 Concetto Single Hole Bathroom Faucet ... - Fixya
www.fixya.com/search/...grohe_3427_concetto.../grohe_faucet_leaks
Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome, grohe faucet leaks related issues. Get free help, solutions & advice from top Grohe experts
Nov 04, 2015 | Grohe 3427 Concetto Single Hole Bathroom...
Tip
How to repair a washer-type bath & shower faucet
  • To take apart a bath/shower faucet for repair, first turn off the water. Then take the faucet apart by removing its handle, escutcheon and packing nut. The packing nut may be buried deeply in the wall, requiring a socket wrench for removal.
  • Your bath and shower faucets may have a renewable seat that can be smoothed with a seat-dressing tool or removed and replaced using a seat wrench. For replacing and repacking the washer, follow the same instructions provided for a washer-type faucet. Some faucets may need a complete replacement of the combination stem/seat unit.
on Jan 16, 2010 | Plumbing
How do I find the site to get replacment parts
Google " Faucet repair parts" and you'll get hundreds of parts stores to choose from.
Jan 26, 2015 | Plumbing
My Graff kitchen faucet just started leaking slowly. What needs to be replaced.
it depends on the type . if new enough it probably has cartridge if old it probably has washers. this is one site I found http://www.chicagofaucetshoppe.com/Graff_Faucet_Parts_s/8628.htm
Jan 22, 2015 | Graff Plumbing
Remove the handle from graff kitchen prescot faucet- stuck
you may have to use a little force gently pry under the handle be extremely careful not to break handle i usually take a piece of wood to put up against faucet or whatever and then tap faucet with hammer then start prying back side with a screwdriver or small breaker bar use your hand to try to wiggle the handle
Aug 30, 2014 | Graff Plumbing
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
Hi, my shower faucet /head drips regularly how to repair the leak?
You need to order seals and replace them. Typically, dirt in the water system damages the rubber (neoprene, plastic) soft parts. Sometimes the damage wrecks metal parts, but this is less common.
Oct 05, 2010 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Replaced single handle shower faucet with rite
u hve to adjust the temprture ring i think u put it all the way so u lock it ,
Dec 25, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Where do i get repair parts for graff shower valve
They can be found easily at amazon, click here: Amazon com graff shower parts and take a look. Have a nice day.
Thom
Dec 01, 2009 | Graff G-7070-LM27S Tango Series Pressure...
Installation of the Graff pop up drain plug
if you losen the nut the bolt is adjustable make sure you tighten nut
Apr 12, 2009 | Plumbing
Plumbing Logo
Top Graff Plumbing Experts
Donni Steen
Tom Chichester
Are you a Graff Plumbing Expert? Answer questions, earn points and help others
