Projecta wont charge above 6amps - Televison & Video
My projecta 15a 7 stage batterie charger stopped working.was a bit hot and now no power, nothing . .???? Any ideas please
you must check your battery charger as i think you have to replace the charger or you can get it repair for more help you can connect with us on the given link http://toolsnyou.com/
Dec 08, 2017 | Cars & Trucks
Projecta charger is shorting out house when plug in
Don't plug it in then and return it. Problem solved!
Just kidding. This means that either your house has a huge flaw, the ground on the plug isn't working, or that your Projector is using too much power.
Jun 02, 2017 | Computers & Internet
I am looking to know how many amps should be the fuse of sinotec lcd tv 32"?? to replace a broken one?? thanks
Hello
The Ampere capacity of the fuse depends on the voltage to which the device is working now. If your Tv works on 220 or 230VAC; use a 4Amps slow blow fuse in place. If it works on 110VAC, use a 6Amps fuse of type mentioned above. OK.
Dec 10, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi, I have a 2000 Boxster S and the battery has started to go flat when the car is not in use. Charging, starter and battery all check out ok, but it seems to be drawing 6amps whn the ignition is switched...
Hello there
to best find out is locate the draw moment and take one fuse ad a time out to see what couse the problem .
It takes a little time but it should work for you.
Mind you all boxters and 996 have a draw problems.
proporsche
Nov 08, 2010 | 1999 Porsche Boxster
Tv wont turn on and i have a blinking standby light. Any suggestions?
Look for Blowed fuse 6amps will be in the middle of chassis ,behind the FBT flyback transfomer and the next most likley cause is your STK ICs they are big black ICs will have part number on them
example STK392-110 Mats Electroniocs has them 1-800-628-1118
If their is anything else you need to know just ASK.Thank You
Jul 02, 2010 | Pioneer PRO-630HD 58" Rear Projection...
My 2004 Explorer will not accelerate, only idles. Disconnected the battery to clean the terminals. Charged the battery on 6amps High for two hours. Started fine but will not accelerate from idle.
verify the gas pedal cable is connected out at the throttle body,you will need to remove the plastic cover that covers the linkage on the throttle body.
Dec 20, 2009 | 2004 Ford Explorer
Televison & Video Logo
Top Televison & Video Experts
