Controller powers up then shuts off - Computers & Internet
Microwave oven will not start - no power
The oven may shut off if the control board detects a problem such as a failed temperature sensor. The control will typically display an error code when this happens. Look for an error code in the display when the oven shuts off.
Another chance will be power failure or a weak breaker could be shutting off the oven. An electrician may need to check the breaker to check for proper power.
Hope this helps.
Shane
Apr 25, 2011 | Ovens
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
When i want to shut down my netbook it wont shut down
If you need to do a hard shut down - you press and hold the power button.
It sounds like you need to adjust your power saving options in the control panel. You are looking to change what the power buttons do. Your power button can be set to "do nothing" when pressed or hibernate the computer or shut it down, etc. You also can have different settings for whether the computer is plugged in or not.
If you are in win 7 - go to control panel. Type "power" in the search in the upper right corner.
Choose "change what the power buttons do" from the list.
You can also access any other items you feel are pertinent.
Jan 10, 2011 | Toshiba Computers & Internet
I lost the manual I need instructions to program it
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Thank You
Sep 12, 2010 | Hitachi VT-RM294A Remote Control
Can a UPS shut off the alarms after going into backup using battery
Usually the alarm controller shuts off the alarm after a preset time.
Most alarm systems have an internal backup battery.
The UPS only supplies power to the controller panel if it is an external power source.
Sep 09, 2010 | Computers & Internet
I DROPPED MY REMOTE AND THE BATTERYS CAME OUT AND NOW I CANT TURN THE CHANNEL SO I NEED TO KNOW HOW TO PROGRAM MY REMOTE
Hi.
Manual Programming:
Thanx
Jul 29, 2010 | Hitachi CLU-5713TSI Remote Control
PLEASE SENT ME ASAP THE PROGRAMMING INSTRUCTIONS FOR THE 538744 REMOTE CONTROL anitilla41@hotmail.com. thank you. asap!
Hi.
Manual Programming:
Thanx
Jul 28, 2010 | Brookstone 538744 Remote Control
DISPLAY SAYS "PF"
HI, there may have been a power surge that shut this unit down or, the junction box may be shorting the power sector. this will damage the main control in this case. i recommend shutting the power off by, pulling the unit plug from the wall socket or, shut the circuit breaker off. let the unit sit for 5 minutes without any power. this will reset the logic chip.
Power the unit back up after this 5 minute wait to see if the reset worked. if the PF is still present, this will confirm a main control fault. replace the control in this case.
**check the power cord junction point for worn connections.
Jul 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Monitor will not shut-off in power save mode
do a virus scan
and then a disk defrag
control settings
click never for standby
and remove check from hibernate
Jan 22, 2009 | Acer Aspire T160 (AST160UA3400) PC Desktop
IR Remote193602
i dont have a code for this brand but there is always the power scan, for dvd power scans, hold down vcr, when all buttons illuminate press 500 then pound, then hold vcr button again, when all buttons illuminate press big red power button, then press up arrow once a second until dvd player shuts off, once it shuts off press pound sign below 9,
Jul 10, 2008 | DISH Network IR Remote Control
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
