Question about Garden
Poluan pro trimmer muffler removal - Garden
2 Suggested Answers
  • 468 Answers
SOURCE: I need the gas mix oil ratio for the Poluan Pro 42...
40:1 gas to oil ratio.
Posted on May 28, 2010
Poulan pro brushcutter ppb150e is starting but cutting off after a few minutes, why is this?
FAQ Trimmers ' Poulan Pro
www.poulanpro.com > Customer Support > FAQ
If the unit has an on/off switch, move it to the on position (usually indicated by the ... This should happen between 1-6 pulls, but no more than 6 pulls. 7. ... Some units use a carburetor which does not require holding the throttle trigger. ... If you smell fuel after following the starting procedure, assume the engine is flooded.
Poulan Pro Trimmer dies when I give it gas.? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 22, 2007 - If you remove the two springs holding that cover on the muffler off you can ... Put it all back together and you should be able to crank up and cut. ... Poulantimmer PPB 100 JUNK, since new hard to start cannot keep running ... If, it sit with fuel in the carb then it may still need cleaned with some Carb Spray.
[PDF]OM, PPB150E, 2007-01, TRIMMERS/EDGERS - Poulan
Nov 25, 2015 | Poulan Garden
My poluan weedeater will start with full choke but
it needs to be adjusted... if you don't have the tool you need to get one or take it somewhere
Aug 28, 2014 | Garden
I have recently bought a poluan pro mower. It has been spitting oil in filter and blowing out white smoke from muffler.
sounds like it is overfilled with oil remove oil fill to level line for motor but white smoke means its getting to much gas or is this two cycle engine wich would mean you mixed oil and gas wrong and to make another batch
Sep 22, 2013 | Poulan "Poulan" Push Mower
Added throttle and cuts out
remove the muffler and run it if runs good open the muffler and clean the screen
May 21, 2012 | Oregon Scientific Complete Carburetor for...
Poulan pro weedeater 330 runs but no power. boggs downs when full trigger pull
remove the muffler and try it if ok open the muffler and clean out the carbon from the screen
Apr 06, 2012 | Poulan Garden
Ryobi 30 cc string trimmer ry34421
try fresh gas then remove the muffler and try it if ok without the muffler open the muffler and clean out the carbon
Apr 06, 2012 | Ryobi Garden
Trimmer runs on half choke only
It's the muffler. Everyone thinks fuel, carburetor, mixture. They're wrong. The muffler is clogged and the unit can't be tuned to high throttle until you clean it.
Steps: Remove the back housing to access the muffler. You may want to remove the gas tank to avoid a spill. Remove the muffler (2 large screws). Remove the muffler door (3 small screws). The screen should be cleaned using a pin (poke out any hardened material). Most important: The muffler door is 2 parts. Pry it apart and scrape off the burnt carbon that is clogging the exhaust path. Re-assemble and start.
Apr 25, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a poulan pro trimmer, it wont stay running
First of all, YES. boggs is a word in my dictionary. Remove the muffler and carefully take it apart. Pay close attention as to how it comes apart because it is vary important it goes back the same way. you will probable find that it is clogged. If it is then remove the debree. If it isn't then you will have to adjust the fuel mixture screw. First start the trimmer, then let it run for a few minutes to warm up, then gently turn the screw a little bit at a time counter clockwise first, squeezing the throttle inbetween adjustments . If it starts to take off then fine tune it untile your happy. If it boggs worse then turn it clockwise.
But first check the muffler.
Good luck
Aug 05, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Could someone tell me how to remove the muffler on a Craftsman 25cc weedwacker?
Look at the plastic cover that covers the muffler. There is probably something that you have to depress to remove it. Once removed you should be able to see the bolts that hold the muffler on.
Jul 31, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
