I have a model# that i need to know if it is a heat pump or just an a/c unit model # n2h324aka100
  • Heating & Co... Master
  • 1,608 Answers
That is a heat pump
Posted on May 14, 2017
I need to know the wiring diagram for the thermostat, which is a 24 vac heat pump thermostat TA2000? HELP!!
What is the thermostat brand name? You can do a search in the Internet for the wiring diagram
Jan 20, 2016 | Gibson Nordyne/2 Ton Heat Pump Package...
I have a Aqua Pro heat pump P130 with error code F5 does anyone know what that means
Error FS?
Unit has started defrost cycle and will reverse operation in 5 minutes.
If coolant has nor res=ached desired temp, unit will shut down and display FS
Other models:
FS can mean not enough water flow in cooling mode.
Mar 25, 2013 | Aqua Pro Swimming Pool Heat Pump 125000...
Have serial # B60700097 older heat pump trying to degtermine year and size?
Hi, according to this serial # it is a 1997 heat pump. I would need to know the model to tell you the tonnage on this unit.
Sincerely,
Shastalaker7
A/C, Contractor
Jul 25, 2011 | Amana Heating & Cooling
I just wanted to know if the heat &air window units use heat resistance com heat pump technology model#580.751245000
Hello Turnbarfie,
If I understand your question right you want to know if the window units that have Heat/Cool air use the same technology as a heat pump. To answer your question yes they do. These units have a reversing valve that pumps the freon on way to cool and the other way to produce cool air.
Thank you for choosing FixYa.com
Justin
Apr 03, 2011 | Kenmore Heating & Cooling
M/n 38brb060300 carrier
Hi, to tell if your unit is a heat-pump or not, if the indoor unit is not gas fired, it is a split system heat pump. If it uses gas or propane gas, its a split system gas/elect unit. Look at your thermostat also. It should have aux heat, emergency heat on it also. Maybe not both, but you will know if you have a heat pump. Please don't forget to rate me. Please be kind, as I know you will. Just remember, no gas, its a heat pump, gas fired furnace indoors, its not a heat pump.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Jul 15, 2010 | Carrier 38CKC060 Air Conditioner
Relocated thermostat non programmable carrier now not working is ther a breaker or a reset on the unit?
Need to know what model it is and if it's a home unit and if it is a two part heat pump system to help give you better answer. If it's a home unit there should be a cut off switch near the pump and there should be fuses inside the cutoff box, this is standard for National electrical code, and if it's a hose unit it should be hard wired to breaker in the house, so if it is hard wired in let me know if it's a portable unit let me know and what model it is thanks for using fix-ya and hope this helps.
Feb 23, 2010 | Heating & Cooling
Hi i need to know the ton of the unit
TYou can find that information on the steel plate on the back of the unit, if it's a heat pump you will find it on the sied where tubing comes out of heat pump. It will have serial Number and model number and you can take that information and go to Carrier and find thw tonage list.
Aug 31, 2009 | Carrier Heating & Cooling
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
What tonnage are these units and is it a variable speed.
The heat pump model number shows that it is a two and a half ton unit. I am sorry but I am not familiar with the air handler model number.
May 07, 2009 | Heating & Cooling
Hi- Can not tell if my unites are straight cool / heat or a heat pump.
if you look inside the condenser unit outside,see if you see the big reversing valve,if not it is a straight cool,heat, the heat strip ins in the air handler so you would have to take the side panel off and look for the heat stripe,my the way heat pumps also have a aux.heat stripe just in case it does not get cold enough outside,hope this helps you-mike
Oct 25, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
