Question about Saeco Coffee Makers & Espresso Machines
I am getting error code 5 on a new saeco minuto coffee machine. What can I do?
Noggin
  • 944 Answers
SOURCE: User manual
Here is the link for the incanto deluxe if that is any use to you; http://www.espressoworkz.co.nz/Incantodeluxesbs.htm bottom right of the page is the download link. This link gives the manual for the incanto sirius; http://www.alattehotte.com/ProductCart/pc/adobepdfs/Incanto%20Sirius%20Eng.pdf Hope this helps, sorry no luck with a manual for the classic :)
Posted on May 06, 2007
SOURCE: Saeco talea ring coffee machine reurning error code
Thanks Johnny,
the machine wont make coffee at all as it stands. Justn returns code 1 as soon as you push the button for coffee. Is the sensor optical or a microswitch? Can you tell me where the sensor is located so that we can have a go at cleaning it?
Posted on Nov 18, 2008
SOURCE: need repair of boiler on saeco coffee vending machine
Coffee Machine Services. 2114 14th St NW (403) 282 4445
Authorized Saeco repair. Great work. Am bringing my machine there today & have used them before.
Posted on Jul 06, 2009
  • 1089 Answers
SOURCE: how to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Posted on Jun 14, 2010
  • 10865 Answers
SOURCE: Saeco xelsis showing error code 1. Machine is
hello clines...error code 1 means the grinder is not working, either the motor is bad or there is no power supply to the motor. Return it to the store or to a Saeco service center.
This has been a common problem with these machines. Shame on Saeco. Joe
Posted on Apr 17, 2011
Error code 5 on saeco minuto coffee machine
Error code 5 means the water flow is obstructed. Here are possible locations:
1- The machine was not descaled. Calcium deposits are clogging the water system.
2- The flow meter is not passing impulses for water flow speed & quantity.
3- Descale Descale Descale.
Before you select the automatic descaling, make a few espresso without adding coffee grounds. The automatic cycle does not clean the coffee side of the machine. You have to do it intentionally.
Dec 18, 2016 | Saeco Coffee Makers & Espresso Machines
What does error code 23 mean on the Saeco Minuto Coffee machine
I believe error 23 is a sensor error for the lever on the front of a minuto.. It cannot be repair at home and would have to go to a service center.
Service Center for Saeco Gaggia Rancilio Spidem Starbucks Espresso Machines
Jun 10, 2015 | Saeco Coffee Makers & Espresso Machines
Saeco xelsis error code 5
Error 5 on your machine usually means it needs a new pump. The pump may be too weak to do the job.
Always try to descale the machine before doing anything else. If you can't then you will have to take it in for service.
Please visit our service center page.
If you need descaler visit this page.
http://www.cerinicoffee.com/espresso-descaler-25/?sort=bestselling
Dec 30, 2013 | Saeco Coffee Makers & Espresso Machines
Saeco error codes
I don't think this is the case. The E04 code is about lubrication of the brew group. This is directly from Saeco support in Germany. However, the problem does persist. It seems to be an issue of poor design more than anything else.
Dec 22, 2013 | Saeco Coffee Makers & Espresso Machines
On my talea ring plus i get an error code 5. anybody knows what that is?
Error 5 is the water circuit is block, or airlock in the system that means you have to purge the air out.
Feb 11, 2010 | Saeco Talea Ring Plus Espresso Maker with...
Hi, I have the Saeco Primea Cappucino Touch Plus , and it syddenly gives the error code 5 - Call assistance. I have just changed the primea Water Filter - same way as always ! What can I do ?
Need to prime the machine. The new water filter is causing the air lock in the system.Remove the filter and startup the machine it should prime by itself, when it's ready,fit the filter back and press hot water until the water flows steady. Hope it helps.
Sep 05, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Coffee Makers & Espresso Machines Logo
69 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
