Question about Pool & Spa
Pool cleaner is not working properly
Pool cleaner is not moving as it usually does
    Top Expert:
  • Pool & Spa Master
  • 6,514 Answers
If voltage to unit bad motor
Posted on Nov 12, 2017
  • 366 Answers
SOURCE: hayward pool cleaner wont move
sounds like the turbine or a-frame bearings are bad. A turbine kit with a-frames will be a solution. Also check the pod shoes for wear, should be a good 1/4" or better.
Posted on Sep 15, 2009
  • 990 Answers
SOURCE: Legend pool cleaner wheels not moving
You might want to pull the drive wheels and see if their might be a small pebel stuck in the drive gears on the wheel.
Posted on Oct 04, 2009
  • 106 Answers
SOURCE: G3 not moving or cleaning. Please advise.
diaphragm is ripped
Posted on Jan 14, 2010
jharwell668
  • 640 Answers
SOURCE: Hayward pool cleaner just goes in circle
If these automatic pool cleaners are moving in circles, it is usually an obstruction in the connection hose. Check the hose to make sure that there are not any knots or kinks that might not be immediately visible. Also, check to make sure that you don't have a partial blockage in either the cord or the throat. You will also want to check the return to make sure it is not allowing too much water to get to the cleaner. You might need to adjust the rear tension flap. Too much tension could cause the cleaner to go in circles. Finally, make sure that the wings and shoes are properly installed.
Posted on Jul 20, 2010
jharwell668
  • 640 Answers
SOURCE: barrcuda inground pool cleaner flips over
Often when you are having this problem with automatic pool cleaners, it has to do with the hose. Make sure that you have plenty of slack in the hose to cover the entire pool. Also, make sure that you do not have any obstructions in the hose and that it is not tangled.
Posted on Jul 28, 2010
Our dirt devil pool cleaner keeps sticking to the pool floor and will not move around, what do we need to do?
Make sure that your unifram is installed with the opening in a vertical position. If it is horizontal, you pool cleaners line will not have proper suction. You will also want to check for obstructions in the flapper that would cause the cleaner to not move properly. Finally, make sure that this is the proper cleaner for your pool size. If you have an in ground or very large above ground pool, it is possible that the pump you are operating with is too strong for the cleaner to move properly.
Apr 09, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
Our baracuda is sucking but not moving. how do we fix it?
Use your flow gauge to check for proper water flow. It might need to be adjusted. This is usually the issue when this problem arises with this pool cleaner. Check the diaphragm for blockage, damage, or ware. Also, make sure that your hose weight is 29 inches from your cleaner.
Feb 19, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Navigator gets hung up at curve going up the pool walls. It has plenty of suction, new rubber feet, clean pool filter running at 3000 rpm,turbine is moving freely with no debis, all suction going to...
You have check all of the things that I would usually recommend when these pool cleaners are moving properly. My additional suggestions would be to make sure that your hose is not too short (adding lengths of hose if necessary) and to check for steering failure. Check and clean your rear screen, make sure that your cone gear is operating smoothly in all directions, and clean, repair, and replace (if necessary) your gear box.
Feb 06, 2011 | Hayward Navigator Pool Cleaner
Robot is in the pool and seems to be on (water is moving above it) however the wheels are not turning
If the wheels stop working on these pool cleaners, it is usually something lodged in the drive train. Check the wheels and axles for leaves, cloth, or other debris and remove if necessary.
Sep 04, 2010 | Smartpool Dolphin Robo - Kleen Above...
Not moving around the pool and nothing trapped inside
With these automatic pool cleaners, if there are no blockages, it is usually a problem with the water flow. Use the water flow gauge and check to make sure that you are getting adequate pressure from the returns. I would also check the wings and shoes to make sure that they are not worn.
Jul 03, 2010 | Hayward Navigator Pool Cleaner
Motor runs unit does not move! What do I do?
On these automatic pool cleaners, this is usually a problem with the impeller. Check your impeller to be sure that there are no obstructions, such as leaves or other debris. Clean if necessary. Also, check your front and rear wheels and axles for things that could have become lodged, preventing or restricting movement.
Jul 02, 2010 | Smartpool Dolphin Robo - Kleen Above...
My robo keen pool cleaner is not moving either forward or backward
This is a pretty common problem with these automatic pool cleaners and it usually has a very easy solution. First, even though this seems obvious, make sure that the cable is uncoiled completely and is not blocking water flow. Secondly, make sure that the filter bag is clean and that the impellers are not blocked. Finally, make sure that there is no debris/leaves caught in the axle bearings of the wheels.
Jun 04, 2010 | Smartpool Dolphin Robo - Kleen Above...
My Pentair legend pool cleaner is not moving
On this automatic pool cleaner, this is usually an easy thing to fix. First, make sure that your filter bag is clean and free of obstructions. Next, take of your head float and shake it. If you can hear water inside, you will need to order a new head float and install it. They are usually inexpensive and easy to replace. Make sure the hose floats are evenly placed and make sure that the cleaner is not getting too much pressure from the return lines.
May 25, 2010 | Pentair White/Gray Legend Platinum...
Apr 03, 2009 | Hayward Navigator Pool Cleaner
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
