Turned the power on at the GPO machine flashed and then nothing, no power. Something seems to have blow, maybe a fuse or similar.
    Genius:
  • 2,494 Answers
Check the circuit breaker on the house,check that none of the hoses have not sprung a leak and sprayed water on the eletric,s..
Posted on May 14, 2017
When the gpo is turned on machine starts to run without pushing on the power button.
It must have had a power cut when it was doing load and saves it in memory where it was last before power cut.
Aug 09, 2013 | Fisher and Paykel Washing Machines
1991 Miata Help! Won't start, nothing at all on key turn, STILL after battery replacement. Help!
The main fuse blew. Look in your fuse box for a big fuse it should be labeled main or master fuse. Replace this fuse and vehicle should work everything but maybe the starting issues. You have a short somewhere. If the fuse blows again or the car won't start repost the problem
Oct 18, 2017 | Mazda MX-5 Miata Cars & Trucks
Fuse short
You may want to check out your regulator. It "cleans" the power coming from the stator. You may be blowing those fuses because of that.
Jul 04, 2012 | Ducati Motorcycles
My Samsung DMR77LHS dishwasher has lost power completely near the end of a cycle. About an inch of water remains. I have power to the unit. I checked the 15 amp fuse in the unit - it had blown. I replaced...
Hi, whenever a fuse of that magnitude, or any fuse really, Blows, you should never just replace it, as to have any device, blow a fuse, trip a breaker, requires a major fault, they do NOT blow spontaneously ever. So you have had a major short circuit inside your machine, at some stage, usually this is in, the main Controller Board, most likely the bridge rectifier has gone short circuit, or a capacitor, But it could be anything even the motor?anything like this then will blow the fuse. The reason the fuse blow is to prevent a fire and explosion or both, as if an unlimited amount of current could be drawn, it would be catastrophic, so a fuse blows to disconnect the power. The Cause of this MUST be discovered before one ever attempts to replace the fuse. Luckily, it seems in this case the fault has blown an open circuit on the main Board, and this has prevented any further trouble.
Really after such an event as this one should engage the services of a professional, as anyone untrained may mis something that later on my even prove fatal. Get this unit looked at by a professional service person, ask for a 'Quote" if concerned about costings, then you can make an informed decision as to what to do.
Your support site is below,
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP06&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=DMR77LHS
Sep 14, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
The amp blow out a speaker box i went to hook a newer box and the power indicator flash on then off i disconnected all of the speaker wires thinking that may be some where there may be a short causing it...
check your amplifiers connections, maybe one has come loose, eg. the ground connection(if this is not properly earthed, this can cause a short, and blow fuses)
Hope this can help..
Aaron
Aug 08, 2009 | Kenwood KAC-9104D Car Audio Amplifier
Fan and compressor will not run
Try replacing the fuses for the condensor.
Apr 24, 2009 | Goodman CKL36AR36 Air Conditioner
Sharp AR-207
I am sure that I don't have to say check the power switch, so you probably have a bad power supply, either not enough voltage, or maybe there was a strong enough surge to knock it out.  Needless to say, if it's under warranty, you should get it serviced.  If not, it'll probably be too costly, and would warrant a new machine.
Oct 26, 2007 | Sharp AR-207 Copier
Electrolux washing machine xc6 aquacycle 1400
Maybe that the door is shut "mechanically" but the micro-switch that indicate the control unit that door is shut,is faulty.
May 24, 2006 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
