Computers & Internet Logo
J
Jane Herbert Posted on May 13, 2017
My card won't register - Computers & Internet
The screen displays PE, machine stops working
PE means Printer Error. your printer is stuck. call a tech
Monitor won't turn on
Try lowering the resolution on TV and raising on PC. Your video card my not handle HD settings such as 1080 dpi or higher. Also use the best input available on your video card. It goes from VGA to DVI to HDMI.
Sony cybershot won't register when plugged in
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Camera won't register that there is a memory card, always saving pics to internal memory
Did you use a high capacity memory card with an old camera? For example, did you use a SDHC card in a somewhat old camera?
Some cameras accept only SD card. Although SDHC card has the same shape, it won't be reconized by the camera.
Sep 23, 2011 • Cameras
Hi, I have a few Casio TE-4500F cash registers, and I am trying to copy the programming from one of the registers to the others using a CF card. I seem to have managed to format the card and save the data...
Oh dear. Why are you wiping the IPL? You are seriously screwing up the firmware in the machine. It might be best to see a dealer to have them change IPLs for you
1helpful
I got my sim blocked unfortunately,,i don't even
Once you have exceeded the maximum number of passcode attempts, the SIM will become locked and won't allow further attempts.
When that happens you must obtain a PUK code (Personal Unblocking Key). This can only be supplied by the network provider to the registered subscriber.
If the SIM is a prepay credit SIM which has never been registered with the network provider, then the PUK code cannot be provided and the SIM card is useless. All data on it such as the phone number, pre-paid credit and any contacts stored on it will be lost.
The telephone number of the SIM card is not necessary in order to generate a PUK code, but the SIM card serial number will be, and it is always printed on the SIM card.
1helpful
I purchased an iphone 4 copy and my phone is showing can not register invalid sim problem
Your cellular provider has to have the phone you are using on file so that the network will recognize your sim card. If you have AT&T you can log onto your account and change it yourself. You can also call and simply say it won't recognize my sim card, they should be able to indicate the phone you are using and it should then register on the network.
My phone keeps saying invalid u sim on every sim i put in it on 3 and wont pick up any network
Is this a new phone? If so, make sure you are putting the sim card in the correct way (some phones are tricky). If you are attempting to add a sim card from a different network than what the phone is registered through, it often won't work unless you jailbreak it (a whole different solution). This is not legal, and often won't give you full capability of the phone. Finally, if you think it is a problem with the sim card, it might be rusty or dirty. Try lightly cleaning it with a soft eraser from a pencil. Good luck!
Grand Canyon Tech
Grand Canyon Tech
