Question about Welding Tools
Need a manual for a ZENY 130 flux core gasless welder
    Top Expert:
  • 43,164 Answers
Try Googling (zeny)(130)(manual) without parens.
Posted on May 14, 2017
From gas to gasless how to
You need to buy single shielded flux cored wire the same size as the wire you have to fit your liner and thats it
You run it just like you would just with no gas the wire burns off flux that shields the arc
Jan 01, 2016 | Welding Tools
How to reverse polarity on transmig 195 for gasless wire
just take the lead for the wire and attach it to the ground terminal and attach the ground wire to the + terminal
there will be diagrams in your user manual and if you don't have a manual then go google and type in--- user manual for mig welder 195 model( model not included in your question)--- and there will be a psd version to down load
Dec 30, 2015 | Welding Tools
Mig gas conversion for JobSmart 125 Flux Wire Welder
The other difference between gas/gasless is the ability to reverse the gun polarity which you can't do with a gasless only welder. You can get it to work but not safely and reliability could be an issue also.
Mar 06, 2012 | Welding Tools
Have solar 110 2172 mig welder does this mig use gas can i use flux core wire also is owners manual available
Yiu can use both innershiel and solid core wire. All you need to do is inverse the polarity for the innershield wire (gasless wire) connect the gun to the ground and ground cable to positive side.
Dec 26, 2010 | Solar Mig Welder Welding Gun Liner Parts...
Can I convert my Cebora Stag 196 welder from gas to gasless
Most gas welders double as gasless welders. Just buy the flux core wire and use it without the gas on.
Jul 07, 2010 | Welding Tools
I have a century powermate 70 mig welder and using .30 fluxcore wire. the machine says that it is gasless also. the machine will not weld right. is this the right wire or what could be wrong?
Check that your ground clamp connection to the weldment is secure (tight).
you can weld with the shielding gas, or without.
by not welding right, what exactly do you mean?
Jun 29, 2010 | Welding Tools
SIP turbo 150 mig welder instructions wanted
for welding cars or similar thickness steel use it on number1 setting speed 6-7 and practise max and min should be used when you want a bit more power A gose onto number 2 and then 3 these are amp settings and are for thickness of steel to be weled your welder can weld up to 8mm of plate steel on setting 3 max i use 0.9mm gasless flux cored wire great for working out doors the wind tends to blow gas away on standard wire yours is easly converted to gasless as so was mine
Nov 02, 2009 | Welding Tools
Got a Campbell Hausfeld gasless 80amp welder. The
Check the tension on the drive wheel, you also might need a liner, they are fairly inexpensive
Aug 07, 2009 | Campbell Hausfeld MIG / Flux Core Wire...
Welding Tools Logo
192 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
