Question about Pentair Pool & Spa
What can I check Pilot light comes on then goes out after 5 seconds does this 2 or 3 times then the green lights on front start flashing off and on and making the clicking noise.
Pentair minimax 400 plus
SOURCE: won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Posted on Dec 09, 2008
  • 366 Answers
SOURCE: do not know how to start pilot light
There should be instructions on the inside of the heater access door. Make sure you are comfortable working with gas heaters. Make sure the shutoff valve supplying gas to the heater is on. Turn the gas valve to "pilot", press and hold it while attempting to light the pilot. Once the pilot is lit, continue holding the gas valve knob down for about 30 seconds. The pilot should stay lit once you release the knob. If the pilot stay lit, turn the gas valve to "on". Replace the heater access door and make sure you have proper water flow and attempt to light the heater. If it will not light, or the pilot will not stay on, you will probably have to replace the pilot generator. It provides voltage to run the heater and after time it wears out and produces less and less voltage. A millivolt heater runs on less than one volt so any power loss can be a problem. If you are able, test the pilot generator with a multimeter to see if you are getting at least 500mv when the pilot is on. If not, you should replace the pilot generator or even the entire pilot assembly. Hope this helps...
Posted on Oct 27, 2009
  • 207 Answers
SOURCE: bradford white power vented hot water tank - pilot light
ur pilot tube may be clogged up try taking it apart and cleaning there is a small small hole on the end that gets clogged up sometimes
Posted on Feb 26, 2010
  • 990 Answers
SOURCE: the pilot light on my pentair minimax ch 250m will
More than likley this is a bad thermocouple and will need a new pilot assembly. But it can also be a short in the safty circut, rat chewed wires or a bad gas valve. It may be best to get a repairman involved. Or you can just drop each switch out of line and jump past them to check. But part changeing can get pricy. Good luck.
Posted on Jun 27, 2010
heatman101
  • 43501 Answers
SOURCE: My pentair minimax plus 250 M pool heater won't
For most pool heaters, if they will not start up in the spring, the problem is corrosion in the wiring somewhere... I would remove and clean all wiring connections and then try. The amount of current is very small and so any bit of corrosion can cause the unit not to work.
It all so could the t-stat again, but you would need to check that with an OHM meter. No continuity when the heater should be on will confirm that the t-stat is bad...
heatman101
Posted on May 14, 2011
When I push the on button the green light comes on for second or two then goes out.(will not stay turned on long enough to even get a picture on the screen.Mitsibishi Model # WS-55315
This set has a self check feature--if set has been unplugged it clears the error buffer--plug in and try to turn on set.
When green light comes on and then goes off ON THE FRONT OF THE SET press and hold BOTH the menu and input(device) buttons at same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat the code for a total of five times.
Let me know what error code you find and I will explain it.
May 27, 2012 | Mitsubishi Televison & Video
I have a Mitsubishi Model WS-65511 the green light on the front was flahing (would not stop) I replaced the 7 Capacitors as was suggested. The light flashed for a while then stopped and turned green
I think I advised you before (on this page you will find a "make a comment button" which allows follow up questions and answers without posting another question.
Green power light now comes on and goes out in few seconds:
On front of set (not the remote) press and hold when that happens both the menu and input buttons for at least 5 seconds and release both.
Power light will blink a 2 digit code like 2 blinks, 2 blinks, pause and repeat that several times---this is an error code---let me know what code you find.
Note: if you have unplugged the set it clears the error codes and you have to plug back and try to turn set on--let it fail and repeat the self check.
SD TECH
Apr 22, 2012 | Mitsubishi WS-65511 65" Rear Projection...
Tv wont turn on green light comes on then goes right out could there be a blown bulb
Do the self check this model has: WHEN GREEN LIGHT COMES ON AND THEN GOES OUT:
On front of set press and hold both the menu and input (device) buttons at the same time and hold both for at least 5 seconds and release both.
Watch the power light, it will blink a two digit error code like: 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find with a comment here and I will tell you what it means.
SD TECH
Feb 02, 2011 | Mitsubishi WS-55613 55" Rear Projection...
"on" light flashes twice and then "blacks out"
IF power light comes on and a few seconds later goes off, do the self check this model has.
On front of set when this happens, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Watch the power light closely, it should blink a two digit error code like; 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65909 65" Rear Projection...
When TV is turned on the green light comes on but the TV does not. 2 seconds later the green light turns back off.
DO THE SELF CHECK THIS SET HAS AND LET ME KNOW WHAT YOU FIND:
When you turn on and green light comes on and then goes off:
On the front of the set press and hold both the Menu and Input buttons at the same time for longer than 5 seconds and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know and if this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Aug 31, 2010 | Mitsubishi WS-65311 65" Rear Projection...
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
Braun Coffeemaker Programming
to prgram the automatic operation, press the automatic buton until the green pilot light begins to flash. The time "12:00" or the previously programmed time appears on the display. When the green pilot light begins to flash, release the button and press the hour and minute buttons until the correct shows; ensure the hours are am or pm. After programming is completed, the green pilot light will go off after 5 seconds.
Dec 08, 2008 | Braun FlavorSelect KF 180 Coffee Maker
Won't come on
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
SONY GRAND WEGA
I have a KDF60XS955. When I power it on, the fan comes on, the standby light flashes green several times, the lamp comes on and the standby light goes to solid green. This lasts for less than 5 seconds then the lamp goes out, followed by ~30 green standby flashes, the lamp coming on with the solid green standby light for about 5 seconds then shuts off the lamp again. I can hear/feel the fan running the enitre time. This cycle continues endlessly. Please help!
May 20, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Pool & Spa Logo
42 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
