Question about Acer Computers & Internet
Acer desktop computer black screen that says updating your system.it's been like this for 2 weeks I tried turning off, unplugging nothing works what can I try to get my computer to boot up
    Diehard:
    Visited the website for 60 consecutive days.
  • Acer Master
  • 635 Answers
If you have the operating system disk.try booting from it using the boot menu f11 f12 keys then do startup repair in window 8.1 of windows 10 it's much harder. try holding down the shift key while rebooting the computer try booting into safe mode, or do a system refresh from the advanced menu
Posted on May 15, 2017
SOURCE: Computer monitor screen stays black
i have a proplem in my monitor, always it appears as lots of screeching thin line whenever i on my PC, is there any solution to solve this problem? please help me.
Posted on Sep 15, 2008
leroyal
  • 2120 Answers
SOURCE: Monitor turning black
the backlight fluorescent bulb is burned out.
Posted on Dec 26, 2008
SOURCE: acer 1640z boots up fine, but no post screen and bleeps
Dear all,
I also posted this one under "Notebook Bios Problems" which might not be the correct place. Anyway here it is for you to see and maybe you can learn from my experience.
Have done a VISTA upgrade with Acers upgrade DVD.
It recommended to upgrade the BIOS - after doing this notebook is dead.
(1 long and 2 short beeps).
If I want to flash a new BIOS with Crisis method which BIOS should I use i.e. how do I know if I need the AT or UMA version - how to verify this on the notebook (my version is 1642 ZWLMI)?
I would very much appreciate some help on this - thank you
LATEST NEW - it WORKS AGAIN:
I was a little bit worried when I started icon_sad.gif but later I was all smiles icon_biggrin.gif icon_biggrin.gif
So a BIG thanks to everyone who posted possible solutions here in this forum:
1: I bought a NEC model UF0002 USB floppy Disk Drive Unit.
2: Downloaded the zip file from the ACER homepage with the BIOS
(chose the one that should be the correct version for VISTA:
It contains 2 WHP files: ZL9A3A24.WPH and ZL9I3A24.WPH as I
learned from NoClaim's post I chose the ZL9I3A24.WPH.
3: Downloaded the zip files with the Crisis recovery zip-file (See d0gi's
post: http://www.rechner.org/b1800.html ).
4: un-zipped the files
5: copies the file ZL9I3A24.WPH into the crisis directory - deleted the
BIOS.WHP that was allready there. And renamed ZL9I3A24.WPH
to BIOS.WHP.
6: ran the WINCRIS.EXE program (did an unbootable format of the floppy)
7: I now had a recovery floppy.
8: all steps above obviously done on my desktop PC.
9: removed battery from my ACER 1640Z laptop
10: unplugged powercable.
11: inserted the USB floppy in one of the USB ports on the laptop
12: pressed the <fn> and <esc> keys
13: plugged the powercord
14: Turned on the laptop
15: waited a bit - lights came on on the laptop (no beeps)
16: waited a little longer and the light on the floppy came on
17: waited still a bit longer until I could hear the floppy was working
and then I let go of the keys <fn> and <esc>
18: after a while there was no activity on the floppy any more and
shortly after the laptop shot down.
19: the laptop started up again on its own and IT WORKED
20: THE LAPTOP IS BACK AND THANKS TO ALL OF YOU I SAVED A LOT
This worked for me and only cost me £5, Here is the web sit i got it from
http://www.wimsbios.com/phpBB2/topic9512.html
Hope it works for you
Tony Swannell
Posted on Jan 13, 2009
romsky79
  • 822 Answers
check secondary power supply budged capacitors and apply fresh solder. check also lamps connectors.
Posted on Jun 02, 2009
  • 788 Answers
SOURCE: Acer Aspire One - blue screen only when try to boot
You may have to remove and reset the HDD and Memory on the unit.
Next, you will recv. the F-2 to continue or F-12 to enter setup.
Enter setup and change date and time.
Save and try.
You may have a damaged HD or boot partition and reloading the operating system will be necessary.
Reseating the HD will assure that you have a good connection and the same with the memory.
Also, if the unit has been dropped, you may have a damaged HD and may need to change it.
Posted on Sep 26, 2009
Why did the careen on the acer aspire V5122p go black after a windows update update
It could be hdd maybe, or just file system. Try to reinstall your os.
Sep 03, 2014 | Acer Aspire One PC Notebook
Flash the bios
DO NOT FLASH THE BIOS PROGRAM
Not trying to be rude, making a statement
Tell me about this laptop.
What is the model name, and model number?
Example, Acer Aspire 5552
Model number is on the bottom of the laptop.
Just black screen one day?
Had problems leading up to it?
Post back in a Comment.
Regards,
joecoolvette
[1) When flashing the BIOS, and power goes off?
You're DONE, unless when asked you saved a copy of the original BIOS; to go back to.
2) Wrong BIOS update? (Flash the BIOS)
BIOS update too new, or not compatible?
You're DONE unless you saved a copy of the original BIOS.
Too easy to turn that laptop into an expensive paperweight.
It is a fact that about two weeks after a laptop, or desktop computer hits the market; that there is an updated BIOS program for it.
But read the above again ]
Apr 02, 2013 | Acer Aspire Computers & Internet
Black screen after Vista Update
try hitting the f8 key repeatedly when you turn own computer and choose safe mode then do a system restore
Dec 02, 2012 | Acer Aspire M1641-U1521A PC Desktop
Hi, I am using an Acer Aspire m3100 desktop PC, and for the past day now it has been acting up. I think it may have either something to do with the overall hardware or the operating system. What...
i,m thinking that the problem is with the hard drive or ram stick
keep an eye out for other replies as there are a couple of experts conversant with laptop problems that can be more accurate
Mar 02, 2017 | Computers & Internet
Upon turning my laptop(acer aspire 9410) on I get as far as login in, then nothing but a black screen. have tried starting in safe mode, but now have black screen with safe mode written on all four corners...
Sounds like your windows explorer isnt starting
Please press control + alt + delete, on the task manager click start new task..
Then type in explorer.exe
that should bring up your windows desktop for you.
Oct 30, 2009 | Acer Aspire 9410 Notebook
My acer desktop will not reboot or start back-up. I did a system clean, and reboot my computer and will not do nothing. It will show window xp then screen will turn blue. I tryed save mode and last convg...
try resetting bios by unplugging computer, hold power button for 30 seconds and try again, update and I will try to help ryanestrud@aol.com rate me please
Oct 10, 2009 | Acer Aspire™ T180 PC Desktop
My acer AL2416w monitor turns on to a black screen
I have 2 Acer AL2416W monitors that i have been using for 2 years. There has been a handful of times i would turn my computer on in the morning and the screen would be black and Acer would lightly flash on the monitor 1 time. Typically a restart would take care of the problem. Last week the monitor blacked out and i can't get it to work. Any suggestions?? I switched ports on the computer to verify it wasn't the video card and tried new DVI cables to verify it wasn't those? Is this fixable??
Sep 06, 2009 | AcerView 77E 17" CRT Monitor
Befor login
i guess you need to post a video and then can anyone tell you something
Jul 30, 2009 | Acer Aspire M1640 Refurbished Intel...
Acer laptop. it won't start up, when i press the start button, it shows nothing but black screen, and i dont know what to do .... I have the same problem i have an ACER ASPIRE 5920, when i turn my laptop...
hi
in both the computers unplug the power cord and any external device attached to the system.
Press the power while the power cord if unplugged for 1 min exact, plug the power cord and see if this works. As there is extra power on the mother board which needs to be drained out
Jan 08, 2009 | Computers & Internet
Acer t180
Did you install some program lately?
If yes,
1.- Start up your computer and before windows start hit F8
2.- You will see a black screen with many options
3.- Select "Safe Mode"
4.- After Windows loaded up, uninstall the last programs.
5.- Restart in normal mode
Sep 25, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
