Question about Plumbing
Psipher kitchen faucet 2 handles cannot find the screw with Phillips dcrewdriver
    Habit-Forming:
  • 154 Answers
Hot water side has an "H" and cold side has "C" pry off these top covers screws are under them
Posted on May 14, 2017
Tip
How to remove Glacier Bay Lever Kitchen Faucet Handles
To remove the lever handle from a Glacier Bay two-handle kitchen sink faucet: Insert a 2.5mm hex wrench into the small hole underneath the lever. Work the wrench into the small handle set screw.Turn the wrench and setscrew counterclockwise to loosen. Pull the Glacier Bay lever handle off the faucet stem. P.S. You do not need to remove the screw to take the handle off.
on Oct 07, 2010 | Globe Union Glacier Bay 8 In Double Handle...
How do you remove the handle to replace valve?
Unscrew top button.
Using a phillips screw driver remove handle retaining screw and work off handle.
If it leaks under the handle you need to unscrew the top cap, use a strap wrench to hold the body and tighten the brass retainer ring with an adjustable wrench. Or remove the ring to replace the cartridge.
Nov 23, 2011 | Price Pfister Marielle Kitchen Faucet with...
Dripping bath faucet circa 1985. Can't ID model but appears to have 2 screws holding front of casting to main body for disassembly . Faceplate is square in shape and black in color HELP!
  • 1 Close the hot and cold water valves in the cabinet beneath the sink to shut the water supply off to the bath faucet.
  • 2 Remove the bath faucet's handle to access the valve cartridge. The faucet handle is removed by first detaching the handle's insert cap using the tip of a screwdriver or utility knife to expose the handle screw. Remove the handle screw with a Phillips screwdriver, then pull the handle off the valve cartridge stem.
  • 3 Loosen and remove the cartridge valve nut with an adjustable wrench. Some faucet models retain the valve cartridge with a snap ring and are removed with snap ring pliers.
  • 4 Pull the old valve cartridge out of the bath faucet base, using pliers.
  • 5 Insert the new replacement valve cartridge into the faucet housing and replace the nut or snap ring removed in Step 3, using an adjustable wrench or snap ring pliers.
  • 6 Reinstall the faucet's handle onto the valve cartridge post, then secure the handle's screw, using a screwdriver.
  • 7 Replace the insert cap into the handle to cover the handle's screw hole.
  • 8 Turn on the hot and cold water valves beneath the sink to restore the water supply.
  • Jun 15, 2011 | Kohler Plumbing
    How do I remove handle? I REMOVE POP OFF COVER & PHILLIPS HEAD SCREW & HANDLE WON'T PULL OFF.
    The handel should pull off it must me caroded up try pulling and twisting it at the same time.
    Jan 21, 2011 | Price Pfister Genesis Luxury Kitchen...
    Moen single handle kitchen faucet, Hot water and
    Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
    Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    We are trying to remove the handle on a delta 172 single handle kitchen faucet. The hex screw won't budge now, but we were able to get the handle a little bit loose. Now not only is the faucet dripping,...
    Make sure the exact allen key is in the screw. take a small adjustable wrench, close it onto the allen key, and loose with wrench turning the allen key.
    good luck
    Oct 09, 2009 | Delta Faucet Delta 172-WF Waterfall Single...
    Single handle, about a year old,leaking at the
    There will be a set screw on back or under cap on top. Remove handle, next use a phillips screw driver to remove the part that holds on to the cartridge. Then a bonnet that unscrews leaving the cartridge easily repaired or replaced. And there you have it.
    Sep 30, 2009 | Plumbing
    No water
    the screw should be a phillips head or allen screw
    May 28, 2009 | Moen 3175 Legend One Handle Shower Faucet...
    Handle on faucet shuts off on its own
    I had the same problem. The Price Pfister web site recommends removing the handle (unscrew the dome cap, then remove the phillips screw to get the handle off) then tightening the retaining ring (I used channel lock pliers on largest setting. It worked. However the retaining ring is plastic on some models, and they recommend replacing it with a brass one. I haven't taken that step yet, we'll see how it goes (mine is plastic).
    Dec 01, 2008 | Price Pfister Marielle Kitchen Faucet with...
    Plumbing Logo
    41 people viewed this question
    Top Plumbing Experts
    Andrew Bugbee
    Tom Chichester
    Gil Shultz
    Are you a Plumbing Expert? Answer questions, earn points and help others
