Question about Samsung Televison & Video
Samsung lcd tv screen went black. still has sound and the backlight is working. was goin to replace the t con board but I'm afraid it could be something else. Anybody have any way to tell for sure?
    Top Expert:
  • Samsung Master
  • 75,417 Answers
Check and replace the T'Con board. If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on May 14, 2017
  • 718 Answers
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
eddiepeezy
  • 130 Answers
SOURCE: I have a 4yr old
It sounds like it may be the voltage inverter to me.
Posted on Feb 04, 2010
  • 11800 Answers
SOURCE: Hi, my Samsung 40" LCD TV's
Actually no board/part is defective - you have a bad contact that when the tv heats up it fails. Since the screen goes totally black but not light goes out on the tv and the sound still goes on then the problem is in the mainboard or the connection between the mainboard and the t-con board - a wide flat cable.
You must open the tv and reseat the connecting cables. If this doesn't fix it then the problem is in a soldering: you will have to remove the boards and check by eye every single soldering - redo all that look suspicious; you will probably have to move the components with your fingers to clearly see a bad soldering in their pins.
Posted on Nov 02, 2010
welcomejee
  • 10594 Answers
SOURCE: I have a Samsung Ln32A450c1d
Basically it is problem of LCD Panel (screen) however some times T-Con board replacement fixed the issue (T-Con board is part of lcd panel but some part shop sell it separately). Main board is not related with this kind of problem.
Required T-Con board is available in ShopJimmy.com (click the link to view available boards)
If T-Con board replacement does not solve half screen vertical lines problem then LCD Panel will be replaced and it would cost approx new tv price.
Hope this info will help.
Thanks.
Posted on Mar 28, 2011
emissionwiz
  • 79865 Answers
SOURCE: Hitachi 32LD8D20UA LCD TV, No Picture, Sound and Backlight Working
Replace the TV, the new ones are cheaper than repairing this one.
Posted on Feb 22, 2012
I have a 32" Samsung LED TV with not picture. Audio is working.
Do flashlight test - if you can see image you need t con board. If no images seen, inverter board. TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 18, 2017 | Samsung Televison & Video
Sanyo DP46142 TV comes on for approximately 30 seconds and then screen goes black. Power LED stays on.
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
May 04, 2017 | Sanyo Televison & Video
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
My samsung ln46c630k1fxza 46 inch t v that has no picture or backlights, i replaced the t-con board, that didnt fix the problem. can you tell me how to fix the problem?
Samsung LED TV Model UN46D6400UFxza has sound but ...
? 2:16
https://www.youtube.com/watch?v=s2hLKzdyDWU
Oct 21, 2013 - Uploaded by Clif Venom
Samsung LED TV Model UN46D6400UFxza has sound but no picture ... LCD & LED TV Repair - No Image ...Missing: ln46c630k1fxza
Samsung LCD TV screen went black (audio on, no picture)
Dec 20, 2015 | Samsung Televison & Video
Samsung LCD TV, no picture, but sound and backlights work. Not t-con board. Any ideas what it could be?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 05, 2015 | Samsung Televison & Video
I have an LG LCD 55LH40 tv where the screen went black. My directv was doing some kind of reboot because we had a power outage, bad weather, and it restarted and the tv was on and the screen said the
Good day..
that problem is cause of bad inverter board or T-con board..
If you have backlight the problem is T-con board..if no back light the problem is inverter board..
Hope it helps..
Jun 13, 2012 | LG 55LH40 55 in. LCD HDTV
Had the LCD TV For 5 Years, no problems, then just before going to bed i was about to turn off the tv when the screen went black but sound was fine. I switched channels and you could hear the channels...
Your problem can be related to either LCD backlight inverter failure or T-con board failure. Please turn on your tv, darken the room and see if you notice a dull glow on the screen. If you see a dull glow then backlight is functional and the t-con is dead. Otherwise it can be a backlight inverter failure(in some cases the backlight itself). In that case I would try replacing the backlight inverter board and hope its not the backlight as the backlight is embedded into the the panel and the only way to replace it is to replace the panel.
Aug 29, 2010 | Televison & Video
My Samsung LN-S4692D
before you give up..call samsung directly, they are very consumer oriented and if it is only a couple months out of warranty you might get them to repair it,, 1 800 samsung
Nov 20, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
Televison & Video Logo
65 people viewed this question
Jerry Greenberg
Jerry Greenberg
