Question about Whirlpool Dishwashers
My whirlpool dishwasher lights keep flashing - Whirlpool Dishwashers
5 Suggested Answers
  • 8 Answers
SOURCE: whirlpool dishwasher ADP905
Depress start button till start light goes out. Close door, drain pump should run for a while. Wait for end of program, rer-try a new program start. This process is re-setting memory.If this fails to sort problem then start checking components, ie: fill valve water on? heaters open circuit/down to earth, drain pump, is it emptying, wash pump.
Posted on Jul 31, 2008
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Posted on Dec 29, 2009
  • 1121 Answers
SOURCE: my adp 4601 dishwasher light on the start button
there a sensor error, motor error, or board defective, send to repair.
Posted on Jan 14, 2010
  • 1010 Answers
SOURCE: Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
Check, if you have water in the machine, if yes, your control board could at fault
Posted on Mar 21, 2013
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Whirlpool dishwasher ADG 957
Try opening the door and holding the start button for 5 seconds to perform a reset. Then try to restart it.
Feb 11, 2008 | Dishwashers
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 06, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
Dishwasher quits running and clean lite keeps flashing.
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 06, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
Whirlpool Quiet Partner V light flashing
most of the time this meens your heat element is burnt out.
Feb 25, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Dishwasher: Green light flashes and will not turn on
Hi
Please press the following sequence to reset the washer "Heated dry" "Normal" Heated Dry" "Normal". This will reset the machine. Also try and locate the tech sheet in lower kickplate.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 10, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
How do i reset my dishwasher adp4504 . i have kept my finger on the start button but just keeps on flashing
Hi!
Try pressing sani rinse and heated dry back and forth. All the lights will light and it will reset itself.
Please see this link for more information---
Whirlpool dishwasher reset
Please rate the solution if found useful.
Thanks
Rylee
Feb 24, 2009 | Whirlpool 18 in. ADP530 Free-standing...
look behind the lower acess panel( toe kick) for the tech sheet, there is aspot cleary labeled "clean light ' blinking 7 times.
Nov 25, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
42 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
