Question about Kitchen Appliances - Others
Kenmore trash compactor
Will not start
SOURCE: Trash Compactor Problem
Had a similar problem with mine. I took it apart and found that the nut that is on the bottom end of the ram screw was loose. I tightened it and it fixed the problem. That was about a month ago. Now it is doing it again. I'm going to tighten it again this weekend and apply Loc-tite to the threads.
To get to the nut, you have to lay the compactor on its side and remove the plate from the bottom. You'll see a chain that goes around the motor sprocket and both ram screws. You need to tighten the nuts on the ram screws.
Hope this helps.
Steve
Posted on Jan 17, 2008
SOURCE: Trash Compactor Removal
I noticed that my compactor attached to the countertop above it at the front, but that it is also possible to do the same at the back. Can you get access under the cabinet at the back of the compactor and check it out?
Posted on Aug 19, 2008
SOURCE: Stuck Trash Compactor
I can't get to the rear of the compactor. How do I get the front off to get to the rest of it?
Posted on Oct 28, 2008
SOURCE: Trash Compactor will not start
key stays on but won't continue running, starts to run and then quite
Posted on Aug 11, 2009
erpaalai
  • 999 Answers
SOURCE: GE trash compactor ZCG3100BVV-02 won't start.
Most likely a ram position switch but could also be a bad motor. process of elimination will lead to the faulty component...Eric
Posted on Sep 12, 2009
Ge profile trash comapctor loud banging noice
You have something wrapped on the compactor screw assembly (The assembly is a threaded rod about 24 inches long and 3/4 inch in diameter. ). Most likely it is plastic bag or some other plastic. Pull the entire compactor out (remove the hold down screws first). Then look for the obstruction on the screw assembly, cut it off and try while not in the compactor hole to make sure it works.
Jun 18, 2014 | GE Profile GCG1580LSS 15" Built-In Trash...
Trash Compactor Thumps
I would guess there is a limit switch that tells the machine to stop once the compactor has retracted.
May 04, 2013 | Kitchen Appliances - Others
Ge compactor stops after just starting
the running cycle for this type of trash compactor is a max of about 30secs. The fuller the bag is the shorter the cycle. However, if this is not how yours is running try checking to see if there is any trash stuck between the ram and the basket. Or make sure that the foot peddle is still staying in the "up" position.
Feb 27, 2012 | GE Stainless Steel Built In Trash...
Does 15" trash compactor need
If the current rating on the name plate is 15A or better, I would have it on it's own breaker
Dec 27, 2010 | KitchenAid P Series Trash Compactor -...
GE trash compactor ZCG3100BVV-02 won't start. I out a new on/off switch and it still will not start
Sep 12, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
Mar 13, 2009 | KitchenAid P Series Trash Compactor -...
Ram will not reverse at end of cycle
ive been a repairman for 17 years but havent had to fix a lot of these because ther not out there,but have done some.it drives on a worm gear and i suspect that theres some wear there and its jumping the gear and thats where your getting the poping noise.their not the funest but you,ll have to take apart and opperate and watch/inspect.hope that helps God bless
Jan 03, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
Hope this helps.
Steve
Nov 20, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
