Question about Plumbing
Dripping. Can not remove handle - Plumbing
Remove handles from price pfister treviso double handle faucet
replace rubber seal in tap need to unscrew the nut to get at it
Nov 27, 2011 | Plumbing
The cold-water handle on my Kohnler K-454-4S Memoirs Widespread Lavatory Faucet is dripping. Kohler sent me replacement cylinder GP77006-RP, but my handyman can't remove the handle without fear of...
He needs a handle puller. Once the screw is removed the handle puller has a long point on it that goes into where the screw was and then the outside of the handel puller clamps around the handle. You then turn the T part of the puller and up come the handle with no damage
Best of luck Rich
Sep 03, 2011 | Kohler K-454-4S Memoirs Widespread...
How do you remove the cold water hand to repair dripping? moen 6410bn
should be able to turn the bottom part of handle and it will bring the handle up with it..the just turn the nut under to replace the cartridge
Dec 08, 2010 | Moen 2 Handle LavatoryWith Drain Assembly...
I am trying to pry the plate off on my Delta Monitor shower faucet. It must be an older model and it is not the plastic handle but a smooth stainless steel handle. It has a plate on the front that will...
I believe the older ones were held on by center threaded on piece, after you remove the handle. It's threaded on behind the handle, round cover over stem. Turn counterclockwise to remove it, then plate should come off.
Oct 31, 2010 | Delta & Single Handle Shower Faucet
HELLO THE FAUCET DRIPS AT THE HANDLE AND THE HOT AND COLD SEEM REVERSED
On this valve the hot/cold in reverse is easy enough to fix, but the faucet dripping at the handle is another issue. To reverse the hot and cold, turn off the house water, relieve the pressure by opening a nearby faucet. Once the water stops, remove the handle and faucet cover so you can see the valve. then the four screws that are visible need to be removed. Mark one of the screw holes with a crayon or pencil and then remove by pulling straight out. Once out, inspect the main o-ring right behind where it sits against the valve, (if this is damaged, it might be why the handle area is leaking) then turn the whole assembly clockwise 180 degrees then insert straight back in and insert screws. Tighten screws until snug. Turn water back on before installing cover and handle to check for leaks. If no leaks are found, install cover and handle and check for proper position of hot and cold. If there are leaks, tighten screws in clockwise rotation tightening each screw a quarter turn, then moving to the next one until dripping stops. If dripping is from center of stem, where the handle attaches, you will need to contact Price Pfister to request a replacement. They are very good to work with. Good luck.
Aug 15, 2010 | Price Pfister Universal 0X8-310A Pressure...
Freeze proof faucet dripping badly (hardly used 6 yr old) bolt holding plastic handle seems pretty well rusted on. I'm trying toi figure out if there is a servicable washer that needs replacement.
I assume that you are refering to a wall mounted hydrant. If that is the case, most do have a bibb washer at the end. You have to remove the packing nut and then the stem to get to it. Some brands you can do this while the handle is still on. Hope this helps.
May 12, 2010 | Plumbing
Kitchen sink keeps dripping...how and what do I need to do to stop the dripping
Is this a single handle faucet or a double handle? If it's a single handle, you have to turn the water off then remove the handle. The set screw for this should be under a little plastic plug under the handle near the base of the handle. After you remove the handle, remove the housing cap to expose the valve ball. Under the valve ball are 2 small circular washers and springs. Pull them out and replace them. If it is a cartridge style faucet like a Moen, then you remove the u shaped retaining ring and pull the cartridge out.
If it is a double handle faucet, remove the handle and using a pair of pliers or a crestent wrench remove the stem. You will find the washer at the base of the stem held on by a screw. It could also be a washerless stem and in that case you will need to replace the whole stem.
If you have anymore questions, just respond to the post and I will get back to you as soon as I can.
Mar 22, 2009 | American Standard Plumbing
Dripping faucet
Moen is a cartridge style unit. They make two different cartridges that you can buy at Home Depot. Turn the water off under the sink and then remove the handle. You will see the the cartridge. It has a U shaped retaining clip that pulls out. Once you remove it, then take a pair of pliers and pull the cartridge out. Take it up to HD and match the one you have. The new one will slide right back in and you will reverse the process.
Mar 15, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Plumbing Logo
32 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
