Question about LG Televison & Video
I cant get my lg tv to switch off av2 - LG Televison & Video
Lg 37lg30 stuck in a loop, it flips between AV2 and DTV1 every 2 seconds. Batteries in remote are fine. Briefly see normal picture when pressing remote buttons before the AV2/DTV1 loop continues. Managed...
Maybe there are buttons on the remote or tv set that are stuck, check these. If no luck then hide the remote so it can't communicate with the set, if it still is acting up unplugg the set for 30 min or more and plug it back in. This may clear a fault that is stuck. If it still is not working correct then the tuner is going bad. Check all devices that are plugged in to the set and unplug them from the tv so the tv does not recognize there is a device connected this may also help.
Sep 24, 2011 | LG 37LG30 37 in. LCD HDTV
I do not have a remote for my model LG 42lc50c and i cannot get to switch from AV2. Is there a way to do this without a remote?
The button that switches from AV2 is the "Input" button, on the lower right side of the TV. But keep in mind, another Audio/Video source needs to be plugged into another input (located on the back of the TV) in order for this to work. The TV has to recognize multiple input sources to switch between them.
Jan 25, 2011 | LG 42LC50C 42 in. LCD TV
When I try to connect a Wii console to my LG television, I put the connection in AV2. But then I get the message that there's no LG signal.
Using the yellow, white and red audio/video cables connect to the side panel of your LG TV and switch the Wii console on. Then press input button on remote and select AV 3 then OK and you should see Wii Menu.
Jan 04, 2010 | LG 37LH30 37 in. LCD HDTV
My plasma LG TV has a black display box in the top left corner of screen. No words or text in it, just a black box covering that coirner of picture...how do I get rid of it?
There should be a button on your TV remote that will be called "Display" or "P in P".
The display button usually displays which input you have selected, such as: SAT for Satellite; AV1, AV2, AV3 or AV4 - depending on how many inputs your TV has, to plug in devices like a VCR or DVD recorder/player.
Otherwise, if you have a more sophisticated TV, it could be that you have accidentally pressed the "P in P" button, that selects the Picture in Picture mode. If you have done this, your TV will display the main picture of the input you have selected, plus another input, (such as SAT or AV1 or AV2 etc. as I've mentioned above). If the AV1 or AV2, etc. input is not active (not switched on) then that input will only display a blank (black) picture in the top left corner of the screen.
Hope this helps...
Nov 17, 2009 | LG 42PX5D 42 in. Plasma HDTV
Useless at setting up. No sound on playback. Blocked timer record
You won`t get round the scan without an aerial.You still can set a recording as long as you set the recording channel as av2.Make sure the scart lead is fully in on dvd and tv,this can lead to no pic but sound,or sound no pic
Oct 27, 2009 | Televison & Video
When trying to switch from AV1 to AV2 with the
The Red, White & Yellow connectors are your composite inputs usually classed as AV3 or component. The AV1 input is a Scart connection, if you have a scart cable, connect this as your AV source & the TV will switch from AV to component.
Oct 24, 2009 | LG Televison & Video
Use of AV2 input sound socketsto play ipod
The sound is muted unless a video signal is detected on this TV. The only work around would be to connect the camcorder or some other active video to tha input but using the IPOD for the audio.
Jul 23, 2009 | LG RZ-17LZ21 17 in. LCD Television
I have an external DVD Recorder / Player attached at my TV via AV1 and an external DVB digital TV box linked to AV2. Both external units are linked togerther to enable direct recording from the external...
I have a LG tv set. When i press the tv/av button on the remote my tv shows av1, av2 earlier but now it is showing only av. So i am unable to watch my dvd player. Need help.
Jul 04, 2009 | LG 37LG30 37 in. LCD HDTV
How can I record digital TV
Use the Av2 socket on the TV and select AV2 on the recorder. You cna only record the channel you are watching
Feb 05, 2008 | LG DR275 Recorder
Televison & Video Logo
128 people viewed this question
Computer Repairing
Computer Repairing
