Question about Garden
I have a rzt50 cub cadet. where does the other end of the positive battery cable hook to?
  • 154 Answers
Well is it a electric start then battery red cable goes from battery red + to starter solenoid battery + term and battery black -- neg cable goes to any ground, if you have a key switch then battery red pos cable goes to key switch batt term and red "S" solenoid then goes to starter switch. the ground stays the same also a black ground goes to ground to key switch this turns it off
Posted on May 14, 2017
Got a cub cadet zero turn rzt50 the throttle cable moves back and forth but will not idle down
Check if the small clamp that holds the cable to the engine is tight. The entire cable may be moving with the throttle rather than just the wire inside the cable.
Oct 02, 2017 | Cub Cadet Garden
What causes my cu cadet rzt50 to sputter & die?
water in gas or a dirty carberator put in new gas and rebuild carb
Jun 28, 2014 | Cub Cadet Garden
Why does my cub cadet rzt50 sputter & die at regular mowing speed?
it is running out of gas bad needle and seat rebuild carb
Cub cadet 7234 no crank no start
Do you think??? probably your problem ---replace voltage regulator
Feb 08, 2014 | Cub Cadet Model 7234 Parts Svc Owners...
I have a cub cadet rzt50 mower...Need to replace a tire
There is a thru bolt, and inside and outside bushing, and center sleeve. Remove those to remove the wheel. Obviously support the frame on a jack. Most tires can be removed using a slight soapy solution and 2 smooth screwdrivers. Replacement, use a soapy solution around the bead, and using only hand pressure put the tire back on. Use a cinch strap around the center of the tire to help keep the tire beads against the rim and air it back up.
Apr 15, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
