Question about TV Box Televison & Video
My World tv box is not showing any signal - TV Box Televison & Video
I have hooked up cable to the RF connector but it will not show a picture. I also tried an anntenna and it does not pick up a picture either. All I get is snow. However, I had a VCR/DVD combo connected and...
This tv is analog tv,will not get today free air tv broadcasting signal.Today free air tv signal are all digital free air broadcasting tv signal now.Anolog tv must have a pay cables tv or satalites tv signals to get a picture on analog tv set.U want analog tv to get the free air digital tv broscasting signal.The analog tv,must have it broadcasting tv signal must go through a box call a Converter box to able to produced a Digital free air broadcasting signal for analog tv to get a digital broadcasting tv signal.
Nov 07, 2010 | RCA F27442 27" TV
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
I have a Sylvanis VCR/DVDcombo and a Standard TV.
The converter box receives hte digital signals and converts them into either channel 3 or 4, or into direct video (red,white,yel). The output of the converter box must go into the VCR input for recording to work. Before the conversion, the tuner of hte VCR would receive the RF signal the same as the TV. The tuner inside the VCR is an analog tuner not digital, so it needs the conversion too. Most converters will provide both the A/V signal (R/Wh/Y) and RF (coax connector).
Hope this helps,
Dan
Sep 30, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
I have a motor home,the signal strenth on my sat. receiver is good, message on screen is "no video signal" Why. Jim
Check the lead's between the sat box & tv are good if the tv is giving the no signal message, if not the sat box may be defective, but try checking all the lead's even up to the dish.
also I dont know where you are in the world but you could be pointing at the wrong satellite, there are lot's up there!
Hope this help's !
Sep 23, 2009 | Sony Playstation 3 (PS3) Console
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Dec 29, 2008 | JVC LT42P789 42 in. LCD TV
DTV converter Box and Zenith system 3
I have the same problem.... On the back of the tv, there are three coax spots. One is for Cable, one is antenna decoder, and another is a loop. I have had zero luck getting any of those to receive the signal. Instead i have ran my digital signal to a vcr, then ran rca cables from it to my tv. I then put my tv in vcr mode, or aux depending on where you hooked it up. You can watch tv through your vcr this way.
Oct 10, 2008 | Zenith C27A24T 27" TV
Not working
first you should know that the uk system is pal and the usa system is ntsc. ok connect your cable box using the rca cable to your converter then out of your converter to you tv. the converter box should have buttons for out and in now remember that pal signal is going in to your converter (it should automatically selected it) but you would probly have to select the signal that is going out of the convert and the signal going out is ntsc so make sure u select out signal to be NTSC. hope i could help
Apr 02, 2008 | Samsung SV5000W VHS VCR
Televison & Video Logo
29 people viewed this question
Top TV Box Televison & Video Experts
electracon
shaun taylor
Are you a TV Box Televison and Video Expert? Answer questions, earn points and help others
