I need a norcent LT-2020 power supply cord replacement - where do I order it? Katherine
4 Suggested Answers
johnny_20
  • 161 Answers
SOURCE: norcent TV Model LT2030 power supply problem
You can get power supplies at a fairly cheap price at surplus shops near your area. Everything in surplus is relatively cheap and relatively dependable. As for installation, that will depend entirely on you, how well you can replace and reconnect wires as needed. You'll have to open it real slowly and carefully, making sure not to force anything out of place. Steady as she goes. You shouldn't need much equipment, a soldering kit will do fine with a pair of pliers and perhaps a small range of screw drivers. Keep your distance when plugging it back in after you've fixed it, just to be safe. :) let me know how it goes.
Posted on Jun 29, 2008
  • 8457 Answers
SOURCE: I need a replacement for the remote to a Norcent
Try website like Remotes.com to buy the original remote.Guarentee it the tv model original remote,warrenty for one year too.
Posted on Jul 07, 2010
gopakumarg43
  • 74887 Answers
SOURCE: power supply para norcent lt 2020
There are two power boards inside Norcent. about which one you talks with? images of both boards are attached. Please give more details, and problem you faces with this set.
Posted on May 12, 2012
Power supply para norcent lt 2020
May 12, 2012 | Norcent Technologies LT-2020 20 in. LCD...
LT2020 screen goe black after five seconds but sound and power is available
Hello Paul, its the inverter board failure, this board supplies power to the LCD back lamp, this needs to be replaced, i'm nor sure about the availability of the part. Try www.usefulparts.com under the manufacturer box. If the board is available have this installed by a technician. Also check out ebay, or do a goggle search for the part.
Feb 24, 2011 | Norcent Technologies LT-2020 20 in. LCD...
Hi, I have a Norcent LT2020 LCD tv and it has a problem, when I hit the power button all it does is flash the on/off led yellow about every 5 seconds, it wont turn on or anything, any suggestions...
Once again power supply problem. With cover removed inspect power supply for swollen or bubbled capacitors such as 1000mfd at 16v or even 2200nfd at 10v. Replace with same value and make sure you use 105 degree replacements for longevity. Let me know how it turns out. Not unusual to change 8 or 9 components.
Thanks: Sam Farrell
Feb 17, 2011 | Norcent Technologies LT-2020 20 in. LCD...
Need to order a power cord for LT-2025W lost in move
My flat panel uses a standard computer / computer monitor power cable. If you are lucky maybe one of those will fit since they are cheap and easy to find.
Good luck and please post back if this helps.
Jan 25, 2011 | Norcent Technologies Televison & Video
Is there a web site that would walk me through removing the power supply board in my 42" Norcent LCD tv?
Very easy to replaced the power supply board.Just take the tv aparts.Use a Philip screw driver take out about 6 philip screws and take out all the board connections to take out the power supply board.Just do the reverse to install the refurbish power supply board that u bought.U can try You Tube,might have video turtoring replacing boards.
Apr 26, 2010 | Norcent Technologies LT-2020 20 in. LCD...
MY NORCENT TV MODEL# LT-3250 KEEPS SHUTTING OFF BY ITS SHELF AND THEN COMES BACK ON BY ITS SHELF
This series of TV's had power supplie troubles. suggest contacting MFG possible recall.
Jun 29, 2009 | Norcent Technologies LT-3250/LT-3251 32...
Norcent technologies LT 2722 27 in LCD
The fuse(s) can be found in the power supply assembly. Check for the letter F follow by a number to locate the fuse.
I service power supplies for LCDs, TVs, Plasmas and many other applications.
Let me know if you further assistance. My email is jah2mil@hotmail.com
May 26, 2008 | Norcent Technologies LT-2722 27 in. LCD...
Norcent not working
We have ten LT-2722 with similar power problems, at beginin the monitor turn on and off after few minutes or hours, then no turns on at all. But the problem is not at the Power Board, is a bad contact or damage in a integrated circuit U403 (GM1501-BD) at the Main Board, unfortunatelly this IC´s pins are unaccessibles so you must replace the all Main Board (Part Number CBPFF84KMGNCT)
Good Luck.
Nov 03, 2007 | Norcent Technologies LT-2723 Television
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
