Question about Kenmore Washing Machines
Taking off the agitator in a Kenmore 500 top load washer
  • 249 Answers
SOURCE: kenmore washer top load
Posted on Nov 30, 2007
  • 943 Answers
SOURCE: kenmore top load washer 110
hi thanks for the question i would check the lid switch very common for that make thanks the appliance doc
Posted on Sep 27, 2008
SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
Posted on Dec 20, 2008
  • 640 Answers
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
Posted on Jan 24, 2009
  • 6784 Answers
SOURCE: Kenmore top load washer top agitator not moving
HI, this is exactly what you need to eliminate this issue.i will list the part number below. you can click on that number to order the kit directly from the parts store if you wish.
Posted on Jun 21, 2009
How do i remove the agitator on my kenmore elite washer
See if the top of the adgitator is removable, there is a bolt way down under the liquid fabric softener and top lid. And possibly a top sealed cover as well...
Aug 02, 2014 | Kenmore 4.3 cu. ft. High-Efficiency...
Kenmore 500 washer agitates, but does not spin. replaced the lid switch with no change. suggestions?
Could be control unit also may be a spin sensor get parts diagram on-line to see if it has spin sensor.
Jun 12, 2011 | Kenmore 24032\24036 Top Load Washer
The clothes are getting stuck under the agitater.
The agitator may have worked itself loose and lifted somewhat upward off the hub...try taking a wooden block and tap with a hammer while placing the block on top of the agitator.
Feb 22, 2011 | Kenmore 22982 Top Load Washer
During spin cylces very load noises----bearings gone less than three old got estimate of 4-500 to fix does that sound right?
Yes, that is a good price for a main bearing repair. I wouldn't recommend it. I would buy either a whirlpool top load washer with and agitator ( we are doing to many repairs on the wp washers without agitators), or I would buy the super capacity front load duet. You will save more money in the long run with the front loader. Both of these have been the best washers built in the last 30 years. Good Luck, Appliance Specialists
Dec 15, 2010 | Kenmore Oasis 27042 Top Load Washer
The upper portion of the agitator (Kenmore Series 80 top load)stopped spinning as if the thread has stripped. What parts need to be replaced?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Basic top load, direct drive Whirlpool / Kenmore washers with two piece agitators use "agitator dogs" to allow the top section of the agitator to turn in one direction only.
These are plastic pieces and over time can wear.
See the following for how to replace them.
Nov 17, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series washer leaves brown grease marks
Remove the agitator and check the shaft seal underneath the plastic drive block at the top of the shaft. Move the shaft in different directions to check the condition of the top bearing. If none or very slight, replace the seal at the top of the shaft supporting post. Clean any grease that is outside of the seal when you are done. Be sure to not damage the seal surface on the shaft when removing/replacing the seal and pre-grease the new seal's inner lip before installing.
Nov 15, 2009 | Kenmore 22422 Top Load Washer
Agitator looks like its stiped on my kenmore elite top load washer
kenmore top loaders have two piece agitator .down inside there are 4 little plastic pieces called dawgs .top should rachet in one direct. haundi24
Jul 03, 2009 | Kenmore 22422 Top Load Washer
Amana top loading washer top agitating
empty washer move agitator clockwise and revese couter clockwise if you don't feel any click at all you had bad part call dog agitator it in side the agitator.good luck
Dec 27, 2008 | Kenmore 24032\24036 Top Load Washer
Open Questions:
Washing Machines Logo
48 people viewed this question
Sal De
 Brian Main
Brian Main
