Question about Garmin GPS
Can I replace the usb port on my garmin nuvi 65LMT with the usb port from a garmin nuvi 40LM
SOURCE: Nuvi 350 System Software Missing
Try this: Hold the power buuton down, you will see on the lower screen the word "Pre Booting - ". Keep holding the power button for about 60 second, then you will see on the lower screen "Booting".
This time, release power button; system will reboot and loading map... again.
I got the same problem, after research on the web. Nick 99990_0 had post this solution on (his Nuvi 660) but it work for my Nuvi 350 too. Good luck.
Minh (NJ)
Posted on Dec 01, 2007
  • 2130 Answers
SOURCE: Garmin NUVI 200W USB Port port pulled loose
The problem with repairing it yourself is that this is a surface mount connector. The solder pads are so small, it would be very difficult to solder with a standard soldering iron. Most likely you would apply too much solder and short out the connector. You really need to use a surface mount soldering/desoldering device and that can be fairly expensive. I have done this before but I have access to the right equipment.
Also, there is a possiblility that the printed circuit board tracks have been pulled up off the main board. If that has happened, there's a lot more work involved in fixing that. You might have to put in a different type of power jack and run wires from it to the main board.
If you're going to try to salvage the USB connector, I would remove it completely and install a new one. Over time, these connectors wear out, so you're better off removing the old one and putting a new one in. Again, this all depends upon whether the tracks on the board have been damaged or not.
Please let me know if I can be of further assistance to you.
Good Luck,
- Jim
You also have to know how to take apart the Nuvi.
Posted on Jul 21, 2008
  • 19396 Answers
SOURCE: garmin gps won't charge while driving
If the Nuvi won't charge when connected to charge but charges on USB, then the charger port is faulty.
If the Nuvin does not charge at all , then the battery must be replaced.
Posted on Apr 13, 2009
  • 171 Answers
If you have a nuvi 350 download the software to your computer and then load the software onto a formatted sd card. Insert the sd card and bootup the Nuvi 350. The sofware will then load onto the Nuvi 350. If you have a Nuvi 200 I would think it works the same but I have not tried it.
Hope this helps
Posted on May 12, 2009
  • 38 Answers
SOURCE: My Nuvi 200 will not charge and the USB port
My condolences. I would suggest you plug the unit in to your computer's USB port using an appropriate data cable (in case you no longer have the Garmin data cable, there are lots of devices, including cameras, that use such a cable with the large USB plug at one end and the mini-USB at the other). That would give you a handle on where the fault lies -- in the auto charger cable itself vs the nuvi's socket. If the nuvi charges from your computer, you're halfway home; if not, I suspect the cost of repairing the nuvi's USB jack could exceed the cost of a replacement unit.
Posted on Mar 16, 2010
How do I update a Nuvi 40lm?
Go to the Garmin site and download and install Garmin Express. Plug your GPS into your PC. The program should identify the GPS and allow you to select from the available updates.
Mar 05, 2017 | Garmin Nuvi 40Lm - Gps Receiver
I would like to register my new Garmin nuvi 65 lmt and fin instruction manual
You register your GPS using the Garmin Express program from Garmin. Down load and install the program, then connect your GPS to your PC. The program will prompt you to register the GPS.
Instruction manual:
Dec 14, 2016 | Garmin nuvi 65LMT 6.1" GPS with Lifetime...
How do you calibrate Nuvi 40LM when the calibration is so badly off?
Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Aug 17, 2016 | Garmin Nuvi40lm Nuvi 40lm Lower 48 Gps...
Garmin nuvi 40lm says map data unavailable?
did you go to the garmin site plug your gps into the computer and down load from the up date .cant help you with out any info .like did you drop it ect ???
Jul 25, 2014 | Garmin Nuvi 40Lm - Gps Receiver
I cat get my battery to charge, its plugged in but it still says low battery.
How old is the battery ??
Batteries have a life span and can only be charged a certain amount of times before they need replacing
Replace battery in garmin nuvi How To Replace Your Garmin Nuvi 40 Battery US $12.75 Approximately AU $12.16 Free postage worlwide
Hope this helps.
Jan 10, 2013 | Garmin Nuvi 40
Gps is frozen (garmin logo ONLY) when I turns it on. Why?
I have installed all suggested updates from the Garmin site, but still do not see my 50 when the USB cable is plugged in.
Dec 10, 2012 | Garmin Nuvi 40Lm - Gps Receiver
Garmin 40LM won't boot all the way
I had the same problem and found the solution on the Garmin website:{4a78cf80-fce4-11e1-e8a7-000000000000}&locale=en_US
Nov 08, 2012 | Garmin Nuvi 40LM Automobile Portable Gps...
My gps 40lm is froze. I can turn it on and off but all I can get is the Garmin logo. Is there a way to fix it?
I've now had two of these devices fail in exactly this way. It appears that this model is unreliable. Call Garmin and get them to send you another GPS unit--preferably not another 40LM, as that will probably just fail again.
Nov 05, 2012 | Garmin Nuvi 40Lm - Gps Receiver
Garmin nuvi 40lm stuck on garmin logo
Following the instructions, at the following link, fixed the problem with my NUVI 40 -{4a78cf80-fce4-11e1-e8a7-000000000000}
Jul 22, 2012 | Garmin nuvi GPS
GPS Logo
41 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
