Question about Craftsman Garden
How to put a craftsman 2700 2.3 ready start pressure washer
  • 391 Answers
SOURCE: Craftsman Pressure Washer 2.3 GPM 2550PSi
if there is a fuel filter running completely out of fuel sometimes allows all of the bad stuff in the fuel tank to plug the fuel filter (if it has one). press the primer bulb until you can hear fuel, then it should start.
Posted on Jun 02, 2010
  • 36 Answers
SOURCE: started by Craftsman 2700 PSI
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
Posted on May 09, 2011
  • 142 Answers
SOURCE: Just purchased a homelite 2700
Check for spark first If it has spark, remove the breather and put a few drops of gas in the carburetor.
Posted on Jun 05, 2011
  • 6 Answers
SOURCE: cant find choke on craftsman 2700 2.3 ready start
If I remember correctly, there is not an operator actuated choke on that unit. It is thermostatically controlled be a device behind the muffler.
Posted on Aug 25, 2013
  • 73 Answers
SOURCE: My Honda homelite 2700 pressure washer doesn't
This kind of thing is happening more often, due mostly from the water supply being hard. You can try tilting it forward and filling the pump with CLR (Calcium Lime Rust sold at box stores) to try and dissolve the calcium out of it. If that doesn't work, you can find a valve kit on EBay from the the number on the pump. If you go this route, I would take the plastic valves, taking photos where necessary. Warning... This only works about 2 out of 10. There are rebuilt pumps on EBay also, but be careful if you order a replacement. They come with the hookup from the rear and from the front, so make sure to get that part right Might save you some misery with RMA's (Return Merchandise Authorization). Good Luck... wish I had an easy answer, but these pumps are notorious for this. Also always take your wand off the pump or sooner or later you won't be able to do it. Also the hose from your spray head, or same thing. And watch the Honda motor when you take it apart; it will fall off if your not careful. Same bolts hold motor and pump.
Posted on May 06, 2014
Is the craftsman gas powered 2700 psi pressure washer to strong to wash cars and trucks?
yes -- it will remove any loose paint then keep going to take all the paint off
if used around the mechanical bits ,it has the pressure to blow in gaskets and force water into places that water would not normally get to
Oct 19, 2015 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Motor runs but no pressure craftsman 2700 easy start
some filter is blocked up or the impeller is full or rubbish
motor runs so impeller should work
no preasure
something blocked hoxe kinken
start valve not actuating {check intake flow sensor}
Jun 04, 2015 | Craftsman Garden
Will not start
is it electric or gas powered?
Dec 16, 2013 | Craftsman 2700 PSI Briggs Stratton...
Cant find choke on craftsman 2700 2.3 ready start 7.75
Aug 25, 2013 | Craftsman 2700 PSI,2.3 GPM Briggs &...
I cant start my power washer. the pull start is locked and wont release to start engine.
When the pull start gets locked, you have to release water pressure from the wand. I had the same problem last year.
Jun 16, 2013 | Craftsman 2700 PSI Briggs Stratton...
Engine lockup
Sounds like the intake or exhaust valve is not opening.
Jun 08, 2013 | Craftsman 2700 PSI Briggs Stratton...
I bought a new craftsman pressure washer 2700psi. Put oil and gas in it. Cranked on the first try. It worked for about 15 minutes and then cut off. Now the pull start is very hard to pull and will not...
Hello
Take out the spark plug and try pulling,if it is still hard then then there is a problem with the pull start mechanism.
Check the plug for oil fouling or fresh oil.If there is excessive oil you may have bad rings.
If in doubt, craftsman will honor the 1 year warranty no questions asked,for a new unit.
Jun 25, 2011 | Craftsman 2700 Max Psi Pressure Washer 23...
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
My Powercraft 9686 pressure washer has always been stored in my garden shed. It is 4 years old and when I used it last September the power washer had lost considerable pressure, as it was leaking water....
put some silicon spray in inlet/outlet then reattach hoses then run it will proform after a while do this everytime you store it pryer to sroring away...........
Jan 17, 2011 | Craftsman 2700 PSI Briggs Stratton...
Garden Logo
32 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
