Question about Health & Beauty
My AquaTouch Aquatec wet & dry 14 months old held a charge for 15 days now down to 4 days is this normal
Ranvens
  • 61 Answers
SOURCE: VAIO VGNTZ150N Laptop battery runs down when not in use
If the laptop is gone into a suspended mode it is still powered on but sleeping. This will continue to use power and will power down the battery over time.
You could enable hibernation which saves the current state of your pc so that when you activate it again it restores to your previous state of work. This will use close to no battery power to perform.
Posted on Apr 24, 2008
  • 210 Answers
SOURCE: dryer runs but will not dry
It may be a thermostat that has gone, thus preventing the heater from going on. Check your power source as well, maybe you have lost a line.
SGt 48
Posted on Jun 18, 2008
  • 14 Answers
SOURCE: wet/dry Panasonic shaver stopped
My model is almost the same as your model ...
Problem: Model ES7037CMB - Over the past month the Panasonic shaver would turn on with 3-4 tries, but now will not turn on at all – the on-off switch must be bad after only 7 months of wet use. Before sending in I found this diagram:
Disassembly: Remove bottom Phillips screw & end cap, pop off each plastic side with fingernails (reinstall them from top 1st), remove 4 screws, remove 2 clips, take top off. Remove battery case and the on-off little, white plastic lever fell out. Slide off the white plastic/metal on-off slider & clean contacts with knife … my bottom contact was black & top was clean.
Assembly: Reinstall on-off slider (white plastic with metal contacts) by sliding back in grooves -- hardest part - place the on-off plastic lever on the battery back unit – I tried to put it on the case and could not get it to stay on. Slide the battery pack back in with the plug prongs in the holes in the end being careful not to drop the on-off lever. Test shaver. Stuff battery wires inside case – screw 4 screws and add 2 clips on, then final screw in the end after cap placed on. Easy once I knew how to put the on-off lever on the battery side – that was tricky. Total time was about 1 hour – next time it will be about 15 minutes. Works great! jgg 12-27-08. Think I will use it dry from now own since it had a lot of whiskers inside of it and maybe wash only the head as needed with baby shampoo.
Posted on Dec 27, 2008
duby1990
  • 370 Answers
SOURCE: Won't come on, just makes a buzzing noise when you turn on knob..
If it makes just a buzzing noise, Your motor has probably gone bad. If you open the doot and hold the door switch in then have someone hit the start button, Then spin the drum by hand and it may start. This tells you that the start windings in the motor are going bad. If this does not work then your motor has totally gone bad.
Posted on Jan 30, 2009
Joed911
  • 4338 Answers
SOURCE: Fully charged mobile battery goes dry within few hours(3 hours)
If it is 8 Mths. old, it should be under warranty.Have the providwer fix the issue.
you can try Kaiser Tweaks:
http://www.jongma.org/KaiserTweak/
***Copied from this link:
http://www.htcwiki.com/thread/935379/Battery+Life
which will change the settings in the registry automatically:
These WILL work, and WILL improve your performance!
1. HKLM\Comm\AsyncMac1\Parms\DisablePowerManagement
Change Dword value from 1 (default) to 0
2. HKLMComm\Irsir1\Parms\DisablePowerManagement
3. HKLM\Comm\PPTP1\Parms\DisablePowerManagement
4. HKLM\Comm\L2TP1\Parms\DisablePowerManagement
To make these registry changes, I used CeRegEditor. Works from the computer and connects to the phone/PPC while synched. I have noticed an improvement in battery life. Should work with WM5 and WM6.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jun 15, 2009
On aquatic shaver do I replace just blades or screens also?
Replacement heads for Philips Norelco Aquatec shavers can be found at shaveroutlet.com. The replacement includes the 3 cutters and 3 combs
Norelco Philips HQ8 Spectra Sensotec Precision Replacement Heads
Nov 03, 2015 | Norelco PowerTouch Aquatec Razor Wet & Dry...
Philips Shaver Faulty
Replacement under warranty involves promising to remove the battery from the old shaver and disposing of the battery and the carcass in an environmentally safe way.
The shaver can be split apart after removing three torx screws and then prising the plastic parts apart against their clips. Be VERY careful when releasing the plastic clips inside because they are brittle and fragile.
On opening the cover containing the battery, motor and control circuitry the ingress of water was clear. The shaver is supposed to be wet and dry, has only been used dry but the exterior has been washed.
The water was displaced using WD40. The shaver operated normally straight away. If your shaver's motor starts with the button but stops again half a second later, the problem might be caused by water ingress.
Dec 16, 2013 | Philips Aquatouch At890 Wet And Dry...
I am trying to register my shaver AT890 for the xtra 12 months
I am having problems filling in a guarantee form for my AT890 wet and dry shaver
Aug 19, 2013 | Philips Aquatouch At890 Wet And Dry...
Philips at896 stopped working
If it's not in warranty, dissassemble the shaver and check for water inside.
Either dry it out in a warm cupboard or displace the water with WD40
Mar 23, 2013 | Philips Aquatouch At890 Wet And Dry...
My iPhone 4 is a few months old and last night it suddenly stopped charging. Of course i didn't realize it until my phone died during the day today and i tried plugging it in and wouldn't ch
The charge adapter maybe faulty.
If your cell phone is a few months old, then it would be still under warranty. Take it back to the place where you purchased it and have it repaired or replaced under warranty.
Jul 26, 2012 | Apple iPhone Smartphone
No power suddenly on the control panel... kenmore elite model 665-1374/665-1384 Worked one day and not the next. Breaker is on, no blockage at water line... connections all tight. It's only 14 months old!
Kenmore dishwashers should be recalled!! Their poorly designed computer circuit boards are all malfunctioning around 15 months. Look on the inside top of your door. Do you see a instructions? There should be some about your Heat Dry button and holding it down for 4 seconds to reset your computer board. Read and try it first. It's like rebooting a computer.
Dec 30, 2009 | Kenmore Dishwashers
14 MONTH OLD TOSHIBA TURNS OFF BY ITSELF
I repair a lot of these and a average tv lasts like 3 years . It is not like the old days. I suspect the lamp or fans or therm protector.
I would call a local tv shop see what they charge for estimate it might be worth his estimate to find out what it is.
Thanks doctor video
May 27, 2008 | Toshiba 52HM95 52" HDTV Projection...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
