Question about Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine
Trotter by Cybex 600C program issue. Doesn't allow to select from the program menu goes to Cardio 1. Doesn't allow increase of intensity or select options in the other menues. Is there a simple fix?
Would disconnecting / reconnecting the battery help? Without taking the bike apart I do not know where the battery is located.
My trotter 510 treadmill doesn't turn on and just gives off this high pitch sound when turned on
oh, the trotter treadmill that is a workhorse of a treadmill. Question doubled edge. does it start?? or it does not Start. the sound if it does turn on may be coming from the motor which may need new brushes. Trotter is now Cybex fitness. they will have a part to make the repair
Oct 12, 2017 | Exercise & Fitness
Cybex 600c trotter bike will not stay in manual mode then display turns off
Does anyone have a Cybex 600C Fitness cycle owner's manual and parts catalog?
Dec 03, 2013 | Cybex Exercise & Fitness
Key pad enter + numbers not working trotter 685
adjust the reed switch, test for open or faulty, clean it, and tight the connector fery weel , see the diagram attached
2) replace the batteries old by new ones, and clean the contacts batteries.
3) tight the ribbon cables for keypads, clean it too.
God bless you
Feb 22, 2013 | Treadmill Doctor Cybex Trotter685 900t By...
Are fitness routines different for women than men?
Fitness boxing for women varies slightly in style. Boxing fitness for women is tailored specifically for women focuses more heavily on whole-body fitness with a stronger emphasis on thighs, legs, **** and back. Male fitness boxing, alternatively, is geared more toward an upper body workout.
Aug 07, 2012 | Boxing
I bought a used Cybex Trotter 700 T treadmill that works fine except the increase speed (+) does not work. I tried to fix it and now all of the buttons don't work. Any sugestions?
Dear Sir:
This is probably a 1(faulty speed sensor or the 2( speed sensor is not plugged in properly. Its also possibly a 3(faulty motor control board or lower board+ 4( Main motor faulty. Adjust the speed sensor see the diagram.
Run the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for HELP
sincerley. God bless you.
ernesto cuadra
managua, nicaragua.
Mar 10, 2012 | Exercise & Fitness
I have a Trotter 535 treadmill. I need to turn
visit wefixfitnessequipment.com and I will tell you how to flip the deck, tighten the belt and where to get lube. If you are planning on flipping the deck make sure you lube it with the right kind of lube!
B. Clark
Trotter/Cybex certified technician
15 years exp.
Dec 12, 2009 | Endurance T3 Treadmill
Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine Logo
1,059 people viewed this question
Top Schiller Medical Experts
Electro Med Services...
Jim Goldsmith
Jim Goldsmith
Are you a Schiller Medical Expert? Answer questions, earn points and help others
