Question about Garden
PTO wont stay engaged on my front deck JD F935. My girl said she hit a large chunk of wood a piece of 2X4? and after that the lever wont stay engaged
2 Suggested Answers
  • 1830 Answers
SOURCE: I have a JD F935 front deck mower the blades will engage but will not lock in the engaged position, girl friend was using it and a large chunk of wood
You might have to replace the blades. They could have been damaged.
Posted on May 13, 2017
I have a John deereL130, deck rusted so I got one from a JD L100 it has a manual pto lever to engage, but my L130 is electric mounted easily,do I need to add tensioners to deck for it to work
On the electric clutch method the belt from the engine pulley to the deck pulley is tight all the time, yes it normally has a idler pulley with a spring to keep it tight. The spring is needed so do not omit it and lock it solid or it will shake itself apart. Hopefully you can copy your L130 deck as well as use the idler and spring from it.
Apr 29, 2016 | Garden
JD 1026R tractor. Why the PTO does not work?
many of this type machine will not engage the PTO if the battery is not full charged or bad
Apr 17, 2016 | Garden
Why can't I engage the mower deck?
Riding Mower Electric PTO Clutch Won't Engage When Hot ...
? 7:16
May 2, 2014 - Uploaded by Steve O The PTO is relatively easy to change assuming that you can get the bolt out of the crankshaft. Basically follow ...
Sep 09, 2015 | Garden
How do i get pto cluch to engage
If this has a lever activiated PTO make sure it is engaged all the way- and the fluid level is good; if it is electrically activated, check that you have power to the switch. If now power at switch- check fuses- if theer is power at switch, the switch is bad.
May 20, 2014 | John Deere Garden
John deere f935 blades engage but will not lock into egaged position
If you want to solve your problem, click on the link I attach.
Best Manuals
Apr 25, 2012 | John Deere Garden
JD Model LX178, 1996 Model year. Engine runs but mower deck will not engage? (worked ok yesterday)
It could be a few things:
1. Check the belt that drives the blades; it could be broken or slipping.
2. Make sure the PTO Switch/Lever is working properly. The cable could be broken, or the spring that sometimes help to engage the blade could be broken.
3. There may also be a large stick lodged in the belt that drives the blades.
Good Luck!
Jul 29, 2011 | John Deere 420,1020,2010,2020,2510,2520...
Engaging the blades / PTO
There is either a yellow toggle switch or a yellow knob type switch on the dash panel that will engage your deck unless some of the safety switches are stopping it from working due to an adjustment problem or a defective switch,let me know if you need more help.
Jul 15, 2010 | John Deere 420,1020,2010,2020,2510,2520...
PTO Tension JD 155C
Look between top of deck and bottom of machine for a rod coming from the rear topside of deck and going up to bottom of machine.Where it connects to machine there is a small pin you must pull to disconnect it.Once done loosen locknut and turn collar in,away from nut,3 or 4 turns to give PTO lever more pull.Tighten locknut,put rod/collar up and over crossbar and into hole it came out of,install pin.You may need to move PTO lever as if you were going to engage blades to help collar line up with hole.
Jan 09, 2010 | John Deere 48 in. EZ Trak Power Flow...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
