Question about Campbell Hausfeld Air Tools & Compressors
Looking for user manual for Husky Air Compressor WL660900AJ (or Campbell Hausfeld WL660800 WL660900). About 5yrs ago someone posted a link regarding same air compressor but that link is dead now.
    Top Expert:
  • Campbell Hau... Master
  • 40,418 Answers
Try Googling (husky)(WL660900AJ)(manual) without parens.
Posted on May 13, 2017
  • 8 Answers
SOURCE: Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
Posted on Mar 15, 2009
  • 98 Answers
SOURCE: I have a Campbell Hausfeld Quick Air DK618300AV without a fuse...
3.5 amp fuse
Posted on Jul 22, 2009
SOURCE: Campbell Hausfeld Air Compressor won't start
The compressor starting problem is common to most of the small portable compressors. Poor design and undersized components are to blame. If you have one of these units i suggest looking into a product called the Smart Start by Conrader Valves. It is interchangeable with the standard air filters and allows the compressor to start without fail. check it out-
Posted on Jul 23, 2009
  • 73 Answers
SOURCE: Campbell Hausfeld extreme duty 4 gallon air
check for a crimped or damaged line going to the presure switch or it might b the presure switch itself
Posted on Oct 17, 2009
  • 4088 Answers
SOURCE: I have a model FP209501 Air Compressor 2 Gallon,
The spray gun consumes more air volume than the compressor can deliver. You can pause painting periodically to allow the compressor to 'catch-up' or buy a larger delivered-volume compressor. The compressor that you have was intended to supply air for pneumatic nailers and staplers in an intermittent fashion. Hope this helps!
Posted on Jan 18, 2010
Looking for manuals for husky air compressor model FP204500AV
The manual and parts breakdown for your compressor can be found at:
If that doesn't work look for it on the Campbell-Hausfeld homepage at under Service and Support. They have been working on the site so some links are not working correctly.
Your compressor is an oil-less type that has very little for you to do as far as service. Mostly you just have to keep it clean and occasionally drain the water from the tank. The frequency of that is dependent on where you are (humidity levels in your area) and how ofter you use it.
May 22, 2012 | Air Tools & Compressors
Husky Manual for TF291201AJ
Go to (its the Campbell-Hausfeld website) and put TF2912 in the 'Find Model' search box and you'll get the operating instructions, parts lists and other information on your compressor.
Oct 16, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Where the oil goes on model wl660001aj aircompressor
I don't find your model ... based on the picture you posted, I would say it is a oil-less compressor. Typically, the oil would be filled through a plug not unlike the one you would find on your lawn mower. Did you not receive a owners manual with this compressor when you purchased it? Have you inquired at either of the Campbell or Husky web sites?
Thanks for for your question @
Apr 01, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
My husky air compressor model is WJ10064AJ. I got this compressor my brother in law. The compressor runs but the pressure is low. It shut off at 75 psi and 75 lbs on air. I have to shut it off for a while...
All of your problems indicate the pressure switch is bad. I don't know which part number to recommend because Campbell Hausfeld (Husky) model numbers have six digits and there aren't any model numbers or part numbers I can find that start with WJ. You need to contact Campbell Hausfeld (1-800-543-6400) to see what part you have to order to fix your compressor.
Mar 21, 2011 | Air Tools & Compressors
Im trying to find brushes for my electric motor in my husky air compressor mod# 417-270
I have not been able to find brushes for your type of compressor. I find a close match on ebay and shave/sand to size. Measure your brushes. Search ebay for "carbon brushes" looking for best price and size needed. Make sure that the armature is still good because the brushes will wear very fast if arm. is bad. Good luck
Feb 13, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have lost my manual to a husky pro 60 gal.air compressor and I need to add more oil, can someone tell me what oil ,seems that i used synthetic 10-30 initialy
either use air compressor engine oil,. or search out a new owners manual from online,. the details will be in there..
Best regards
Jan 05, 2011 | Campbell Hausfeld Air Tools & Compressors
Need to find out how to replace belt on WL65 cambell hausfeld air compressor
Not sure how easy it will be to locate repair instructions if they are not in your manual. However maybe the diagram of the pump is all you need. Just click on the first link below. It will open up the pump diagram. #14 is the belt.
I also included the link to the site where you can get a look a at the parts list and order parts for your compressor.
Hope something here helps.
If not please let me know and I'll try and describe the proccess for the belt remove to you.
Pump diagram:
Compressor diagram and parts list:
Pump parts list:
Nov 19, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Piston snaped on my husky 1.7 hp 32 gallon
I have had sad service with Campbell Hausfeld. You can go to their website, type in the model number, then ask for recalls on that model. My guess is there is no recall.
If not, you might consider buying a replacement compressor motor to mount on that tank.. The tank is too good to throw away. Try
May 07, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
63 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
