Question about Garden
Does a yard machine have a fusible link on the starter?
5 Suggested Answers
raffaiel
  • 209 Answers
SOURCE: CHANGED FUSIBLE LINK 16 GUAGE A FEW TIMES. KEEPS
there's a grounded wiring on your car or it is not tighten hard... check your wiring harness...
Posted on Apr 30, 2009
litoshop
  • 298 Answers
SOURCE: fusible link
HI CHECK FOR STRIPED A POSITIVE WIRE TOUCHING GROUND AND IF EVERYTHING LOOKS OK THEN SUSPECT A FAULTY STARTER GOOD LUCK
Posted on Sep 02, 2009
rtpflh
  • 546 Answers
SOURCE: There are two wires with no power at starter. The
a burnt[blown] fusible link must be replaced with a new one ,usually soldered in place, starting circuit is only energised w/switch in start position.trace wires & check connectors.
Posted on Sep 30, 2009
nobody322
  • 20706 Answers
SOURCE: Honda Civic 2005 LX automatic 1.7L. Replaced battery and alternator. Battery light is showing. I am told either wiring is bad or a fusible link that goes to the starer then alternator. Help. Put on
why not use a 10 buck voltmeter take the readings and
see why, (alldata.com has the schematic)
look at the alt. first question we say to self is, is reg in alt or reg in ecu/pcm
now matter, meter black to body ground. battery minus best.
20vdc range
red test lead, battery + 12.6v, good, now the big stud on back of
alternator. 12.6. if not this line is open, (yes there is a fuse)
the fuse box,with big fuses, all are 12v on each end, if not that one is bad. not 12v.
now the alternator connnector.
1 pin is IGN, its 12vdc key if not, dash wiring.
2nd pin, charge lamp (battery) is tad less than 12vdc, thus its glowing key on,
next pin, if the tricky pin, the ecu charge wire. testing this is impossible with out real FSM on car.
the alternator case running must not read above 0v, or the alternator ground is bad.
i say a guy last year replace an alt 5 times
and the battery cables were bad.
the alt say the open and SHUT down.
i does that as a feature so as not to go way high voltage
and blow up every thing in car at 24volts. for sure.
i can get to my accounts, blocked on vacation in South america
seems is it eCU CONTROLLED
but they use lots of engines world wide, 1.7L not sure all are same. so i do FSM time. or alldata.com and look.
one good post is this, they stay on track , rare that.
no sure if you have a
http://honda-tech.com/honda-civic-2001-2005-78/battery-light-still-new-battery-new-alternator-plus-new-issues-3019040/
is your scan tool working??
ELD failure
is top of list. it controls charging,and is on recall for spikes blowing up expensive electronics,(random victims)
lots of posts world wide on ELD fails.
Posted on Jan 08, 2015
Does a yard machine lawn mower have a fusible link on the starter relay
it may have a fuse on the starter relay but unlikley as on a vehicle
May 13, 2017 | Garden
No power in the swith starter
I'll guess that what you mean is there is no power to the starter switch. It would help, always, to know what you are working on, but in general, most cars have fusible links to protect major circuits. Yours may have blown a fusible link powering the ignition switch, or if you meant the starter solenoid, perhaps the link to it. If you are unfamiliar with these links, google "fusible links".
Jul 14, 2015 | Cars & Trucks
85 ford tempo injector curcit has no power, checked curit with nod light and did not get a power response. cloud you try to help
  • There is a fuse panel located behind the left hand side of the instrument panel. Check to see if the fuel injector fuse is good. Should the fuse look good then it is time to get out the multi meter or test light and diagnose the harness. I have put up a diagram and a description of the the points to check. Sometimes it comes down to diagnosing. Check the fuse first.
  • Fusible link C, Fusible link G, Fusible link J, Fusible link P, Fusible link R supply power to the EFI system.
  1. Fuse Link A: At LH Strut Tower.
  2. Fuse Link B: At LH Strut Tower.
  3. Fuse Link C: LH Side Of Engine Compartment, At Starter Relay.
  4. Fuse Link D: LH Side Of Engine Compartment, At Starter Relay.
  5. Fuse Link E: At LH Strut Tower.
  6. Fuse Link F: LH Side Of Engine Compartment, At Starter Relay.
  7. Fuse Link G: Front Of LH Strut Tower, In Tape Out To C107.
  8. Fuse Link H: At LH Strut Tower.
  9. Fuse Link J: LH Side Of Engine Compartment, At Starter Relay.
  10. Fuse Link P: LH Rear Of Engine Compartment, In Tape Out To C106.
  11. Fuse Link R: LH Side Of Engine Compartment, At Starter Relay.
  12. Fuse Panel: Behind LH Side Of Instrument Panel, Right Of Steering Column.
Regards, Tony
Apr 30, 2011 | 1985 Ford Tempo
Fusible link john deere lt133: where is it?
ive put two selodnoi on my lt133, they told me the it was lack of ground, so I cut the connector of the black wire out of the selanoi and put a lug on direct to ground and still can get power on the seloenoi goin to the starter
Mar 19, 2011 | Yard Machines Garden
I reversed the cables on battery and now the truck will not start
Look for a blown fuse,or fusible links to be burned out,these fusible links will bolt onto the starter with the positive cable,I do not know what year it is,but if it is a newer model,there is a fuse on the rail,on passengers side,near the radiator,it will be a flat fuse with two mounting bolts on each side of it,150 amp,or 200 amp,or lower,disconnect the battery before replacing it.
May 10, 2010 | Chevrolet C1500 Cars & Trucks
1994 geo prism, fuse blew, I don't have manual
the only fuse for the starter is not located in the fuse box it is located in the positive wires that go to the starter its called a fusible link and when then amperage of the starter exceeds the fusible link rating the fusible link blows the link is usually located inthe positive wire to the starter and at some point fatter then the wire itself
May 04, 2010 | 1990 Geo Prizm
79 chevy k10 starter problems
Fusible Links
The engine compartment wiring harness has several fusible links. The same size wire with a special hypalon insulation must be used when replacing a fusible link.
The links are located in the following areas:
  1. A molded splice at the starter solenoid Bat terminal, a 14 gauge red wire.
  2. A 16 gauge red fusible link at the junction block to protect the unfused wiring of 12 gauge or larger wire. This link stops at the bulkhead connector.
  3. The alternator warning light and field circuitry is protected by a 20 gauge red wire fusible link used in the battery feed to voltage regular #3 terminal. The link is installed as a molded splice in the circuit at the junction block.
  4. The ammeter circuit is protected by two 20 gauge fusible links installed as molded splices in the circuit at the junction block and battery to starter circuit.
Other things it MIGHT be are the ignition switch, located on top of the steering column:
The other thing it MIGHT be is a faulty ignition cylinder (where your key goes into to start the K10).
Check the wire harness on the steering column also.
Oct 28, 2009 | 1983 Chevrolet C1500
If the fusable link at the starter is broken
if just the starter fusible link is burned then you should have power to and from the switch, and also power before but not after the fusible link itself. if this is the case you may actually have a bad starter. fusible links burn out for a reason. of course, you'd have to replace the burned fusible link as well.
Sep 30, 2009 | 1999 GMC Safari
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
