Question about Garden
Model 944.605150 mower deck cable hook up - Garden
  • 148 Answers
SOURCE: need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
You can download a free copy at www.managemyhome.com or you can go to www.searspartsdirect.com and buy a copy along with look at the diagram that you need.
Posted on Jul 23, 2009
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
SOURCE: 20 hp 42 in. Deck Lawn Tractor - CA Model: can you give me a diagram for a craftsman mower de...
i have a 16.5 hp with a 42 deck for some reason one blade cuts alot lower then the other is there a way to adjust thanks
Posted on Jun 16, 2010
SOURCE: i need a deck diagram for a 19.5 hp 42' cut
Craftsman 42 in deck makes terrible noise and middle wheel shakes. started while mowing.
Posted on Jul 30, 2010
  • 6468 Answers
SOURCE: john deere model LA105, deck engagement cable spring keeps breaking.
are you routing it the right way rubbing or kinked
Posted on Apr 04, 2012
My blade cable came loose at the lever and i dont no what to hook it to
is the cable intact? Look at the ends and see if you can tell if the cable is broken.
Aug 17, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you replace the deck engagement cable on a cub cadet ltx 1040
there is a pin,like the ones that hold the deck on,on the end of the cable,pull it up and off to get the cable out,
Aug 11, 2012 | Garden
Blade engager is disconected under the mower where the cable comes out. theres a spring at the end of the cable and i do not know where it hooks.
There are four pulleys on your deck. The two larger ones drive the blades, the two smaller ones are idler and tension. The idler is on the left, the tensioner is on the right. On top of the small one on the right, in and forward of the one that drives the right blade, this is the tension pulley. With the deck fully lowered, feel the skinny metal piece that rises out of the middle of it, at the top there is a hole. A bee clip goes in the hole. The spring on the end of the cable hooks over this rod and the clip keeps it in place. Your clip either has broken or become dislodged. Look on the mower deck for it. If you can not find it the clip is very similar in size to the one that holds the cable in place on the back of the deck. If necessary, remove this one and test fit it in the hold above the tensioner pulley and go to the hardware store for a replacement.
If youare unable to locate a replacement, let me know and I will describe for you how to order one.
Jul 25, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a deck diagram for a 19.5 hp 42' cut
Jul 26, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Murray ridinglawn mower will not start..everything is new
sounds like you have a safety switch issue, i am the proud owner of 3 different Murray mowers, you have a seat switch, a blade disengage switch, and a clutch pedal switch, depending on model and year, unplug one at a time and re try, need anymore info, email me, niteman87@aol.com :) hope that helps,
May 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a model 13AH762F752 MTD Lawn Tractor on the front the bar that holds up the mower deck which way should it go in.? If you are looking at the tractor from the front R or L
if the mower deck is on the ground under the tractor raise the front of the deck up and push the deck towards the front u ntil the tabs are lined up with the hooks on the deck..good luck
Apr 06, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Ayp lt 4218 c k gro riding mower. need to hook deck up. have parts no idea where they go or how.
go to searspartsdirect.com enter model # of the tractor they will show diagrams of the deck & how to replace parts
Jun 12, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I would like to see the manual on how the mower deck is hooked up and where the cables go.the tractor works good but the deck is screwed up.
I'm going to need some information.
1) What is the make of the mower.
2) What is the model number.
Regards,
May 15, 2009 | Classic Accessories Garden
How do you remove the mower deck from a craftsman riding lawn mower
Most of these have a cable to pull deck into gear, which has a r clip to remove ,than two rods that go from font of deck towards front axle- remove 2 R clips to drop them, and 2 more at the back of deck, un hook belt around engine pulley, than slide deck out. See how this goes. Or you my have dune it by now.
Dec 15, 2008 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
