Question about Seiko Watches
Is there a way to dk a factory or hard reset on the Seiko se322fs?
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
My watch has had the battery changed and when you reset the stopwatch, the second hand and the small hour/minute hands no longer rests on 12. How do I reset these hands
I have the same problem with my Seiko Coutura Chronograph. Ever since battery was changed, the stopwatch resets to 32' 8" instead of 0'0". How to re-zero the hands?
May 08, 2010 | Watches
The chronograph second hand now resets to the 5 O-Clock position?
I have found instructions that tell you how to reset the hands but there are several buttons on your watch and to avoid confusion you really need to see a diagram.
You can do this by going to the Seiko web site (seiko.com), click on "support", then "instruction booklets".
Scroll down the next page and you will see a list of the watches made by Seiko. Select yours and download.
Go to page 16.
Jan 23, 2010 | Watches
I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
Seiko watch stop watch needs resetting
You can download an instruction manual for your watch here. It will detail how to reset the hands. :)
Tom
Nov 10, 2009 | Seiko Men's Stainless Steel Chronograph
The ease of repairing Seiko watches.
No. First off no watchmaker has a "parts account" with Seiko. Seiko only sells watchbands to watchmakers. All other Seiko parts are sold through supply houses.
Seiko parts are not hard to find most times. The very old Seikos will have parts issues and some of the current styles of Japan only Seikos will not have parts available.
Case tubes for all Seiko watches are not available at all.
Finding parts for Seiko watches requires the use of the watches model number which is on the case back of the watch. The number listed in the title is not a model number. The SKA098 is a retailers number so the retailers can reorder the watch. It does not cross reference for parts.
There are many watchmakers that don't want to service Seiko watches so they can and do make up all kinds of stories as to why it is impossible to repair them and so on.
Actually Seiko is much better about parts supply than any of the Swiss watch companies.
Hope this helps.
Ken
Yellowstone Watch Inc.
Oct 01, 2009 | Seiko SKA098 Wrist Watch
Hands problem
Download the instruction booklet from here
http://www.seiko.co.uk/support/instructionbooklets
May 05, 2009 | Seiko SNXJ92 Wrist Watch
Resetting a SEIKO watch
You may can find instructions here:
http://www.seikousa.com/#FAQ
Go through the watches till you find the match.
Rate me, please.
Mar 14, 2009 | Seiko 0512037FA Wrist Watch
Resetting the 'day'
Your Seiko has two pulls,first pull for DAY / DATE,and the second pull for the hour and minute.Just do the first pull then wind it clockwise for DAY and the counter clockwise for DATE.Feel free to ask whatever the result...
Hope this may help;
Regards,
VOTIT
Sep 03, 2008 | Seiko 0512037FA Wrist Watch
I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
Apr 27, 2008 | Seiko 0512039FA Wrist Watch
Watches Logo
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
