Question about Garden
Does a yard machine lawn mower have a fusible link on the starter relay
    Top Expert:
  • Garden Master
  • 48,269 Answers
It may have a fuse on the starter relay but unlikley as on a vehicle
Posted on May 13, 2017
How do i change starter pulley for yard machines lawn mower
do you need to replace the rope or just replace the starter clutch? check this link for those parts,, if you reply to this answer, I will assist you in whatever it is you need,
Sep 10, 2011 | Yard Machines Garden
I have a 2001 yard machine riding mower that cuts off when it gets warm and has no electric
Symptoms would lead me to the coil. They get hot, and die. If it doesn't re-start hot but will after cooling down then its a 99% coil issue
Also after it shuts down and u turn the key to try to start it back up is the starter engaging and trying to spin the motor or are you getting nothing.
If the starter isn't doing anything it could be the starter or relay between ignition switch and starter.
If the starter is engaging and the motor is trying to turn over it could a weak starter or it could be a build up of compression not letting the starter spin it over that a valve adjustment would help. The temp change from cold to hot is sometimes enough make the valves expand and not open enough to release compression for start up.
May 29, 2011 | Mtd 22" Yard Machine Push Mower
I have a Yard Machine lawn mower (Model # 11A-41MY229). I lost the manual. When I pull the chord the motor turns but it won't start. It has plenty of gas. Do these lawn mowers have a starter fuse that...
How old is this lawn mower, and have you replaced the spark plug recently?
Also, check to make sure the air filter is not clogged, preventing the engine from breathing.
May 02, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
Need wiring diagram
There is a safety switch under the seat as well as attached to the clutch pedal
Jul 26, 2010 | Yard Machines 155 Torque Briggs Stratton...
My yard machine mower will not start it just just
sounds like the starter is locked up. but start by checking for loose connections
Nov 06, 2009 | Mtd 22" Yard Machine Push Mower
Batery is good new starter new starter relay wont start dash comes on when key is turned but wont turn over or even click its like there is no power to starter it all starter when i jumped my lawn mower i...
did you check main fuses under hood, and also check for brunt fusible links,(looks like wire but inside bruns like a fuse).if everything is good then next step is ignition switch. hope this helps.
Oct 12, 2009 | 1996 Dodge Neon
Starter rope broke on yard machine
Take the top off. Remove broken rope. Rewind spring until tight, then unwind one turn. Insert and knot new rope.
Jun 07, 2009 | Mtd 22" Yard Machine Push Mower
Broken starter cord MTD Model 125-478R062
try this link.
you will want use size #4 or 4.5 starter rope. about 7 foot in length.
Mar 17, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
