Question about Power Computers & Internet
Have a 40018. Was working when we had a power outage. When power was restored the 40018 did not come on. Can you help????
What do I do after power outage and monitor will not work?
If the device was plugged in when the outage started and / or when power was restored - it may have suffered a power outage related voltage "spike" (or instantaneous rise in voltage greater than it is designed to handle).
Unplug it for 5 - 10 minutes and reconnect. If it fails to function you may need repairs or replacement. Try a different monitor on the computer before condemning it - it may be a problem with the computer's video card instead.
Mar 11, 2015 | Computers & Internet
How to restore voicemail after power outage avaya
The only way to restore the setting is through a Backup & Restore card plugged into the system. Also check the system batteries. This will keep power to system during an outage.
May 21, 2014 | Avaya Eurostyle 18D Corded Phone
Restore incoming call rings after power outage AVAYA
If you have a Backup & Restore card you can manually restore the system. If not you will have to restore everything by manually including voicemail greetings and automated attendants.
May 21, 2014 | Avaya Corded Phone avaparp18d
Power outage and fridge doesnt come back on when power is restored
First make sure there is power to the plug at the wall. If not check the breaker. If power at the plug, the power outage could have been associated with a power surge that killed your refrig.
Mar 21, 2014 | Whirlpool WRF560SMY 19.6 cu. ft. French...
Have power but not freezing, cannot hear motor, recently had power outage
Hello max ryan,
I understand that you had a power outage and now that power was restored, you have power inside the appliance but the freezer is not freezing and you can't hear the motor running. I would double check the breakers and make sure that they are on. You can also check the Temperature Control and make sure that it is not in the OFF position. If these solutions do not work, I would call the manufacturer for more help.
-Best Regards-
Jan 04, 2014 | Frigidaire 13.7 cu. ft. / 388 liter...
Vizia VPT 24 - LCD not working, switch not working after power outage
faulty switch ? faulty breaker ? loose connection ?
get an electrician to test the circuit.
Dec 23, 2013 | Leviton Vizia + VP00R-7LZ Accessory Dimmer...
I have a model 40018 electronic clock. This clock
if you hold down the button on top that says DST for like 10 seconds it will allow you to force change the time.
Mar 17, 2010 | Equity Time USA Audio Players & Recorders
Computers & Internet Logo
23 people viewed this question
Top Power Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
