Seiko SE322FS NO SOUND,PIC OR LED LIGHT - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 40,473 Answers
There could be an open internal fuse or power supply failure
Posted on May 13, 2017
My Seiko led light flashes blue and red i get the logo to start with and that's all the lights keep flashing i have no pic
You do have Video or else the picture of your screen would not appear. I suggest you look at the INPUT, for example the lines into the TV, HDMI cords etc. If you have an extra TV or even a computer monitor, wire it up and see if these devices provide an active video stream. In short, the problem has to be external or with the input section of the TV.
Feb 04, 2018 | Televison & Video
Could be an open internal fuse or power supply failure
Jun 01, 2017 | Seiki Televison & Video
How to do factory reset on SEIKI SE322FS
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 13, 2017 | Seiki Televison & Video
Black screen on seiko led tv
Depends on the make and model of the unit. You did not say what it is. Some have bad LED backlight strips and others have bad inverters or PSU's.
Dec 09, 2016 | Televison & Video
I have sound but no picture on my 32 in Seiki T.V. Model no. SE322FS What is my problem?
turn on the tv. press menu? can you see a menu? if not. your tv requires service.
can you see a menu? might be a connection issue. if you can see a menu respond
Feb 18, 2015 | SEIKI Digital SE322FS 32" LED TV 1366x768,...
Seiki se322fs won't turn on
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 16, 2014 | SEIKI Digital SE322FS 32" LED TV 1366x768,...
SEIKI SE322FS LED TV won't turn on, but power light is on
From your description there are blown electrolytic capacitors on the power supply board,a visual inspection will show bulged burst or leaky caps.I am assuming there is no sound or pic and no visible light from the screen.I must assume you have no prior electrical service knowledge and warn of possible high voltages being present on the primary side of the power supply at the 400volt filter cap
also be sure to unplug the set before removing the back pannel
keep safe
Oct 13, 2014 | SEIKI Digital SE322FS 32" LED TV 1366x768,...
I have a 32in seiki model no.se322fs no pic no sound how can i fix it?
Couple things here. A lot of the flat panels and projectors will shut down after a few minutes if no signal is present so I would not worry about that. The first thing to check is all of your connections and then check that your TV is on the same input you have the cables plugged into. Most remotes with have an "input" or a "source" button to toggle through the inputs.
Sep 11, 2014 | Seiki Televison & Video
My tv won't work after I shut it off using the remote throught the cable box
You need to turn on the cable box again. Make sure to select the right source again for your tv.
Jan 11, 2014 | Seiki 32" LED HDTV SE322FS - CAM CONSUMER...
Televison & Video Logo
Top Televison & Video Experts
