Question about Troy-Bilt Garden
Replaced drive and transmission belts on a troy-bilt riding mower and now it runs very slow.
This mower ran fine before replacing belts. Belts are installed correctly per the manual. I have adjusted the acceleration pedal as far as possible and this did nothing to help.
SOURCE: belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Posted on May 05, 2009
  • 376 Answers
SOURCE: belts coming off lawn mower troy built 46" 21hp horse 14at809h766
Go to... http://www.managemyhome.com/mmh/owner_manuals and enter your model # that under the seat.
Posted on May 25, 2009
  • 18 Answers
SOURCE: troy built riding mower runs at low speed and
Probably an engine problem.
Does it run at max rpm with mower deck disengaged?
Posted on Apr 18, 2010
SOURCE: I just replaced the drive
The bronco is a variable speed mower from what I remember. There is a belt that goes from the crankshaft to a variable speed pulley and another belt from the variable to the transmission. If your 1st belt is too long it will never get up to speed. Do you have to push the pedal down further now than before to get it to move. ? If so your main belt is too long.
Posted on Jun 05, 2011
  • 6468 Answers
SOURCE: Troy bilt riding mower will not move fwd in gear
check the linkage adjustment
Posted on May 21, 2012
Troy-bilt bronco riding mower hydrostat drive will not move mower
be sure the drive rod is engaged on the back of the mower. pulled out should be free move and in should be the drive position. if it is in check the belts are in good shape and not off of a pulley.
Feb 05, 2017 | Troy-Bilt Garden
Belt is to long, is there a deck adjustment?
Jim, Double check to make sure you have correct belt for the deck and are installing it in the correct configuration as per manual or drawing on deck. Very few lawn tractors have deck belt adjustment, most do not, most deck belts have a spring loaded tensioner to take up the slack.
This could be some of your problem, the tensioner/idler pulley sometimes seize up and must be lubed up till they move freely, or your belt could be loose. Look in your manual or try google searching your make, model #, deck belt adjustment.
How to Change Riding Lawn Mower Deck Belt
Mower belt tensioner repair question to the Garage Gang
lawn mower deck belt routing Google Search
May 20, 2016 | Garden
Install new drive belts and mower still wont move forward or reverse.
Belts dont move mower back and forth, there is a bar that engage the hidrolic transfer, perhaps you move it and you have not tracking power, or, there are a series of rods that actuate the hidrolic, coud be that any of those rods came undone, if any of these to scenarios is happening to you, consider have the hidrolics chec out.
Good luck to you.
If you need further help, reach me via phone at https://www.6ya.com/expert/gerardo_79638d1eac6a0a1f
Jun 27, 2015 | Troy Bilt 175HP Manual 42" Riding Mower
Troy bilt zero turn mower runs but does not move
Make sure the gears are engaged. There are 2 metal hooks on the rear of the mower, 1 on each side, if they are pulled out the mower is out of gear, make sure to slide them over so they retract back into the mower. If not the problem, sounds like either broken drive belts or the transmission isn't working properly.
Jul 02, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Belt adustments for a ride on murry mower
hello ann, as far as i know there is no belt adjustment on a riding mower, the tenser pulleys keeps the belt tight, if there is access slack than the belt is stretched and needs replacing,hope this helps,
Feb 15, 2012 | Garden
Replace drive belts
Lowe's or Home Depot has the drive belts for this mower. Just stop by to your local one and ask them for it.
Hope this helped!!
Aug 09, 2011 | Troy Bilt 22HP Hydrostatic 46" Riding...
Garden Logo
71 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
