2006 Chevy Silverado ac
No cool air but compressor working
    Habit-Forming:
  • 154 Answers
Okay compressor will always work... there is a clutch behind pulley wheel if no or low Freon in system clutch will keep trying to engage but wont... so in your case 1 system needs to be recharged... on clutch needs replacing.. or there is 2 safety switches one on the low side and 1 on the high side... anyway unless you are an mechanic then you can't fix it need special tool and will cost more to buy tools
you can't release the used Freon into the air it against the law... if its the its easier to replace whole compressor with clutch already installed no special tools needed but system need to be discharged which you cant do.. also special tool needed to look for and find leaks...
Posted on May 13, 2017
I have a 2006 chevy uplander a/c stopped working spent $1000.to fix still no cool air checked cabin filter and vent doors all ok.Then replaced the a/c compressor and still no cool air.$1400 I spent ev
Usually cooling gas is missing, go to some car AC service and fill it. Do it in short, otherwise could damage be higher and in meantime keep AC switched off to prevent damage. Call more services for better price.
Aug 29, 2014 | Heating & Cooling
I have a 2000 Chevy silverado 1500, the AC isn't
2000 silverado Visit the on-line store, known as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Dec 27, 2017 | Cars & Trucks
Where is the blend door actuator located on 2006 Chevy Silverado?
My ac works, but my heater blows cold air. Is there any way I can replace actuator by going thru the glove compartment?
Nov 04, 2012 | 2001 Chevrolet Silverado
Compressor clicks 2000 chevy silverado 1500 5.3L
First thing is have the AC charge checked by a shop, if that is OK then the AC compressor low side pressure switch may be defective or the compressor relay is defective.
Jul 26, 2017 | Chevrolet Silverado 1500 Cars & Trucks
2006 Chevy Silverado 1500 z71 4x4 the ac wont kick off after key is out of the ignition and it only blows hot air.
I am assuming you mean the blower will not stop with the key off.
The compressor can't run with the engine off.
I would look for a stuck blower relay.
Jul 05, 2012 | Chevrolet Silverado 1500 Cars & Trucks
On a 2001 chevy silverado 2500HD the ac blows cool in idle or slow speeds but while driving the air gets warm and then cool warm and then cool etc. i cant tell if the compressor is cutting on and off
You might be low on freon if not compressor going bad to see if your compressor is going on and off turn on a/c on max have some one hold gas peddle down around 1500 rpm or just at a small fast idleif compressor goes on and off recharge it most likely one or two cans will be enough
Aug 24, 2011 | 1999 Chevrolet Silverado 1500
Ac only cools when accelerator is pressed. when sitting in idle traffic, only blows warm air. had ac recharged, doesn't help.
I have same issue. I took to Chevy dealer they could not find problem (whats new) then I took to trusted mechanic.
They measured voltage at compressor and found out when idle the voltage dips below manufacturer specs, then when RPMS go up it gets more juice so the compressor then starts to work properly.
Chevy claims its made that way to extend compressor life.
Jul 11, 2010 | 2006 Chevrolet Equinox
Airconditioner temperture cooling on and off
be sure to check your vacum hoes sometime if there stop up they wont let the air circulate
Sep 12, 2008 | 2000 Chevrolet Silverado
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
