Auto light rapidly flashing green light. I turn power off, unit runs for about 2 mins then stops and flashes same light. What do you think?
It is a comfortaire mini-split unit Model number is B-SMH18SB
  • 400 Answers
SOURCE: Kelvinator Highwall Split Model KSE70CRA
The unit is tripping when the outdoor unit tries to come on. This could be two things, first change the capacitor on the outdoor unit by removing the top cover of the outdoor unit. If this does not solve the problem, your compressor could be faulty
Posted on Mar 05, 2009
  • 3 Answers
SOURCE: TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Posted on Apr 18, 2010
  • 3 Answers
SOURCE: Toyo Aircon. Starts perfectly. Runs
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
welcomejee
  • 10594 Answers
SOURCE: unit turns on green light
Let me help you to solve this tv problem.
Does standby or any other light blink red at tv front when tv refuse to turn On?
If yes, please count how many times red light is blinking after 3 seconds long pause.
Did you inspected lamp in tv?
Is it Sony KDF-55XS955 tv or any other model tv?
Let me know above info to solve this problem.
Thanks.
Posted on Nov 06, 2010
  • 77 Answers
SOURCE: The green auto light keeps
Need model and make of unit? Take off the bottom door of your furnace and there will be a label on the inside or the outside of the door it will tell you what the flashed mean.
Posted on Nov 25, 2010
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
Constant flashing red light near on/off switch
i think it is the power supply board problem
Nov 05, 2013 | Televison & Video
Thermal Dynamics cutmaster 81. when turned on it cycles blowing air but no arc. two green lights are flashing. pulling the trigger doesn't do anything, air keeps cycling
Hi; Check the following troubleshoot and see if you can ID the problem:
Problem: Gas flows continuously when power is turned on, AC indicator flashes 1. Torch switch is activated (closed) before user turns power on. a. Release torch switch. 2. Faulty torch switch a. Check torch switch for continuity. Replace if necessary.
Problem: Gas flows continuously; Torch will not pilot when torch switch is activated; AC indicator ON 1. System is in SET mode a. Change to RUN / Rapid Auto Restart / SET switch to RUN (up).
Mostly of the problems found is that customer has the switch line on to SET instead of RUN.
Hope this help. Have a good afternoon.
Sep 16, 2011 | Welding Tools
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
The green auto light keeps flashing on the head unit of my a/c and i can not turn the unit on. It has power, it does work, every now and then the green auto led stops flashing and i can use the unit with...
Nov 25, 2010 | Heating & Cooling
Green light of "hell"
Try reinitializing the set press menu 8970
Oct 13, 2009 | Mitsubishi WS-65615 65" TV
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
REMOTE CONTROLS WILL NOT WORK-WALL BUTTON FLASHING RAPIDLY
Does your wall switch have a lock feature? By pressing the lock button, the remote control is disabled. A flashing light indicates this feature has been activated.
To deactivate, press and hold the lock button for 2 seconds. The flashing should stop and your remote should work again.
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
