Question about Malber Washing Machines
Malber p21 ships rinsing
It skips first wash and rinsing
  • 163 Answers
SOURCE: Malber p21 spin
the lid switch must be broken if you know how to use an screw driver you can fix it remove the lid witch and replace with a new one, remember to unplug the machine frome the wall...good luck
Posted on Aug 06, 2006
SOURCE: My washing machine won't fill with water
I have my washer connected to the kitchen sink. In order for it to fill I have to connect the hose to the faucet and turn it on, it is pain but that is the only way it will work for me. I hope this helps.
Posted on Aug 22, 2007
  • 641 Answers
SOURCE: bleach/fabric softener compartment
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Posted on Sep 06, 2007
SOURCE: washer is jumping extremely only when spinning
I own a Malber WD1000, which is several years old. Recently, I had it transported a couple thousand miles across country, and due to the size of the pickup truck it was in, the machine had to lay on its side for the duration of the trip. Shortly afterward, the machine began making a loud banging noise during the spin cycle. Additionally, the door gasket had a "wrinkled" appearance.
After taking various panels off of the machine, I discovered the culprit. The insides of the machine (drum, etc), are more or less suspended inside the outer housing. This is accomplished by means of a pair of shock absorbers on the bottom, and a pair of large springs on top. This allows the inner workings to shake a little bit during the spin cycles, without transferring the vibrations to your floor. In my unit, one of the upper springs had come loose from the frame. The solution involved tipping the machine on its side, with the top cover off, and pulling the end of the spring back through the mounting hole in the frame, then finding a nut and bolt to occupy the additional space in the hole, so that the spring could not slip back out. Getting the end of the suspension spring properly seated again was no small task, but it solved the problem, and now the washer works just great again.
Long story short, I'd check to see if all the springs are in the proper place.
Posted on Apr 01, 2008
  • 19396 Answers
SOURCE: oko-lavamat 6200 washing mashine does not rinse
When this happens it is usually a problem with the timer. By replacing the timer/programmer you should be able to fix it.
You can find parts here:
If you input model number on this website you will get replacement parts price.
Posted on Jul 13, 2008
My washer skips the last spin drain? It ticks from 5 to STOP very quickly and clothes are still dripping wet.
Time to replace your timer sounds like you have a mechanical timer not too difficult to do.Work safe.
Dec 03, 2014 | Malber P21 Front Load Washer
Where in florida can I get a malber p21 washer and get the dementions of it. I have one in NY and love it
A Malber P21 has the following dimensions:
Height:33 1/2"
Width:23 1/2"
Depth:20 7/8"
(From the AJ Madison Web Site)
The model is discontinued, though.
The current model is the P31.
It's an Italian model sold primarily in the New York area.
You may want to call Malber at 516.323.5299. or email INFO@MALBERAPPLIANCE.COM.
Oct 17, 2014 | Malber P21 Front Load Washer
My malber washing machine p21 will not turn on it is making a clicking sound but nothing else
It might be due to the switch problem or wire will be cutted for that which runs the engine... Check the wiring and switch on the machine..
Apr 01, 2012 | Malber P21 Front Load Washer
What do the icons on the washins machine means?
Please refer to the manuals of the washer.
The three main icons are for wash, rinse and dry. The other icons are the for error codes, and heating.
Dec 29, 2011 | Malber P21 Front Load Washer
I'm a general contractor. I made up a new hose by using various couplings
and a speedy connector.
Jun 25, 2009 | Malber P21 Front Load Washer
Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Dec 02, 2008 | Malber P21 Front Load Washer
Door handle
I have done this myself, breaking same part and fixing. For parts call 718-767-7396 in NY. I hope they will ship to you if you are not in NY. Good luck!
Jan 16, 2008 | Malber P21 Front Load Washer
Sep 15, 2006 | Malber P21 Front Load Washer
Washing Machines Logo
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
