The start light of my Thomas Hobbes rh1042 washing machine keeps blinking when I try to start washing. what does this mean?
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
SOURCE: The start button will not stop blinking.
I hit start and then it started operating in test mode and ran through some tests. I now seems to work fine.
Posted on Jan 11, 2009
  • 56 Answers
SOURCE: WASHING MACHINE WON'T RESTART!!
try unpluggin unit for 10 or 15 minutes sometimes a computer will lock up. If this doesnt fix it there is a tech sheet located behind the lower removable panel (3 screws down on your knees and look up a little between the door panel and lower panel. Tech sheet can help you with minor problems but be careful parts are expensive and non-refunadable (electrical parts). always disconnect power before working on unit
Posted on May 30, 2009
TheMobilian
  • 8220 Answers
SOURCE: the washing machine keeps blinking sud what does
Either you have too much of the correct detergent in there or the wrong detergent in there. Here are a few of the errors:
1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
2)Excessive vibration: noisey,roar, knocking noises. Bad damper,bearing or broken trunion. no error code
3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
6)Door open, Door not latched, clothes/objects keeping door from completly closing. Tighten door latch, add washers if nessesary to make good contact and close door tighter in case of leaks.
7)Cold water does not enter washer: hoses connected backwards. Oops.
8)Oversudsing: Wrong Detergent, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. Remove detergent, retry
9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
10)Water heating error, hE, the thermister/heater is out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 01, 2010
SOURCE: My kenmore 575-0 dishwasher is
Mine started doing that 3 weeks ago. Did you get a 'fix' for the problem?
Posted on Jan 09, 2011
Washing machine starts washing then stops mid cycle
The clothes become very heavy once water is added. Please try remove some of the clothes to reduce weight Karen. Thank you and let us know if this helps? Leave feedback
Jul 12, 2016 | Russell Hobbs RH1042 Frontload Washing...
Washing machine will not start, only get two red flashing lights, what could be the problem ?
Sounds like something toasted on the control panel
Better call certified appliance repairman
Oct 08, 2014 | Russell Hobbs RH1042 Frontload Washing...
Washing machine keeps filling up with water kno matter what setting it is on even on the drain setting
You have a problem with your knob or switch it may be burned out I would get on Craigslist and find a free one meaning a matching one or a whole working unit there on there all the time in free stuff sometimes matching sets
Aug 07, 2014 | Russell Hobbs RH1042 Frontload Washing...
Wshing machine keeps filling with water
You probably have a stuck fill valve. This is the part where the hot and cold water hoses connect. Just to be sure unplug the machine and if it still fills Remove and replace the fill valve assembly. Don't forget to unplug the machine and turn off both the hot and cold water supply valves. This is a rather simple repair.
Flashing lights doesn't complete spin
I think this indicates a fault i.e. unbalanced load, I had the same when I tried to washable pillow. Went through all cycles but spin.
Nov 09, 2013 | Russell Hobbs RH1042 Frontload Washing...
Which button is spin on my russell hobbs rh1042 washing machine
The second to last on the dial (picture of a spiral), if it's the same as mine.
Nov 06, 2013 | Russell Hobbs RH1042 Frontload Washing...
My washing machine russell hobbs rh1042 gets half way in to a cycle then stops and lights start flashing what does this mean
Your machine is trying to tell you something-do you have the owners manual-if you don't I'd bet you could find it online-what I would look for is an explanation of the flashings-it will probably tell you to count the number of flashes to tell you what is going on-cheers denny
Oct 24, 2013 | Russell Hobbs RH1042 Frontload Washing...
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
