Question about RCA Audio Players & Recorders
I am looking for a TV code for my RCA flat screen so I can pair my Zune player. Can you help me, please?
  • 85 Answers
SOURCE: RCA tv.speakers internal
buy another speaker of your tv for replacement
Posted on Jun 03, 2008
SOURCE: When I turn on my tv, I get a black screen that says unusable signal. I change the channel, same thing. I try to use the DVD player or another add on and it is still black. My TV is an RCA 37in flat s
Thank you ryolkowski!!!! We just tried your solution and MAN it worked like a damn. We were all ready to make a trip to the city to get a new tv, an expense we just didn't need right now. You made our day. I can't thank you enough. jabo
Posted on Aug 02, 2009
SOURCE: Have RCA L32HD31R flat screen TV. Codes for
Need 5 digit codes for Direct TV remote, not 3 digit. I have a RCA flat screen and tried all 16 codes as per instruction from online PDF manuel and none of them work for me either.
Posted on Feb 17, 2010
  • 666 Answers
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Posted on Mar 26, 2010
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
I am looking for the codes to run my t.v. my t.v. brand is Panasonic and the universal remote I am using is RCA RCU800MS 8-Device Universal Remote. I lost the code book and was wondering if I could get the...
The codes I have are: Code 003 for Panasonic TV
Code 054 for Panasonic TV
Code 055 for Panasonic TV
Code 062 for Panasonic TV
Code 109 for Panasonic TV
Code 130 for Panasonic TV
Code 170 for Panasonic TV
Code 214 for Panasonic TV
Code 350 for Panasonic TV
Code 351 for Panasonic TV
The codes can be looked up here: for most RCA remotes. Please note these codes will work for TVs released at least 6 months before the remote was programmed.
I hope this helps.
Nov 19, 2010 | RCA Televison & Video
How do i download youtube videos to my zune
please kindly try this software,Wondershare FLV converter can help Zune users convert FLV to Zune compatible files. If you meet situations like this, you can refer to this detailed guide to convert your FLV videos with ease.
Nov 24, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune and yamaha RX-V663 Receiver
Buy the Zune A/V kit and hook it up to a non used rca port on the back. Look for the older ones for the 30 gb units, they are much cheaper than the new ones and it takes 10 seconds to modify them to use on the newer units. The A/V kit has 3 rca plugs, one for sound and 2 for video. If you pick a source that can play video and sound on your receiver, then the screen on the zune will display on your television. The A/V kit has a remote with it also so you can control the zune from the room. I have not tried it, but since the Zune remote is IR then if you have a good all in one remote, such as a harmony, you may be able to program the codes from the Zune remote into it and even be able to control your stereo and Zune from one remote. Hope this helps.
Jan 31, 2009 | Yamaha RX-V463 Receiver
I am trying to connect an akai dvd player to directv, please help
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
Jan 31, 2009 | Akai DVD-3850S DVD Player
Need codes
If you don´t get any help, ask here. They are specialists in finding remote codes. Send them the model # of remote and TV or DVD Player you want to control.
Jan 19, 2009 | RCA Universal Remote Control
Zune lock
If you forget the code, you must erase the device. The Zune device automatically prompts you to erase the data after you enter the incorrect code three times in a row.
To change or disable the screen lock, follow these steps:
  1. On the home screen of your Zune device, select Settings, and then press the center of the Zune pad.
  2. Select Screen Lock, and then press the center of the Zune pad.
  3. Select Disable Screen Lock or Change Lock Code, and then press the center of the Zune pad.
  4. Enter your code to continue, and then follow the prompts on screen.
thanks to our buddies over at microsoft.
Jan 04, 2009 | Microsoft Zune JS8-00001 Digital Media...
Dvd player connection to tv
possible reason could be:the cables are corrected wrongly,if you use RCA type please ensure the color coding is correct and are firmly in place..
Nov 06, 2008 | Sharp 21" Multi System Stereo TV
Need TV Code
trying to program my sharp tv and lost the manual to program my tv need the steps to program it help me
Oct 07, 2008 | RCA RCR412C Remote Control
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
