Question about Kenmore Sewing Machines
Kenmore 19050/19550, I can not figure the proper sequence of numbers to se up for a gathering stitch
  • Kenmore Master
  • 11,462 Answers
All you need to do is set the machine to a straight stitch with the longest stitch length possible. One more thing that is helpful is to loosen the upper tension so you can pull the bobbin thread to gather.
Posted on May 14, 2017
How do I get a good running stitch?
Not specific to your machine - a secret to easier gathering is to drop the tension on the upper thread by 1 or 2 numbers before sewing that gathering line. Then, you pull the bobbin thread when you gather. It will gather MUCH easier. Just don't forget to put the tension back to normal before you start regular sewing again! Temporarily switch to another color bobbin if you're afraid you might forget which is which - you'll be pulling it out anyway. I think most people gather with a stitch that is just .5 mm longer than they're using for construction.
Mar 24, 2015 | Janome Harmony 2041
I have decor pro99 and it is not sewing button holes properly it's missing stitches and just before the end it just gathers up
The link below features 3 different videos on YouTube for you machine. Maybe there is something there that will help.
Mar 09, 2015 | Sewing Machines
How to change stich to long stich for gathering? is the manual for your machine; look at p. 27. You want stitch 00, and then increase the stitch length with the up/down buttons on the control panel.
p. 24 of the pdf covers adjusting the top tension of the machine; you'll have an easier time of gathering if you reduce the top tension about 1-2 number setting.
May 29, 2014 | Singer 5400 Sew Mate 60-Stitch Sewing...
Designer 1 my gathering stitch is not working properly
if you have the machine set for the gathering stitch & it's not working, then you might think about having the machine checked
May 14, 2012 | Husqvarna Designer I
Kenmore 1941 sewing machine irregular stitches
try rethreading the machine top & bobbin make sure to get ever thread guide
try chaning to needle, make sure the needle goes all the way into the needle holder-normally flat side goes to the back of the machine
check to make the thread is moving smoothly around the tension dial
if these suggestion don't help, then the machine probably could use a servicing
Mar 13, 2012 | Sewing Machines
How to do gathered stitches on j3-20 series
Gathering stitches is same on most makes and models, you just set up for a straight stitch but turn stitch length up to 4 and loosen off the top tension by one number, ie turn it down a little. Then sew two straight stitch seams where you want to gather, one at 10mm from raw edge and one at 20mm from raw edge, leaving long thread tails on both. Then draw up the bobbin (underside) thread to gather the fabric.
Jan 04, 2012 | Janome Sewing Machines
When i do gathers on my machine i use the largest sticth,but the gathers r hard to pull. y/
Stitch length of 4, loosen your top tension by half a number and always pull up the bobbin threads.
If you need to gather yards of fabric then get a gathering foot. Janome make one - it looks like this
This foot is for creating soft gathers in lightweight fabrics. The underside of the foot is raised behind the needle and has a thick bar in front of the needle to gather the fabric. This works great to create the gathers as you sew. You can also gather and attach a ruffle onto a flat piece of fabric simultaneously, run the flat fabric through the top groove of the foot and the underneath fabric is gathered and stitched to the top piece, you need to keep the bottom piece feeding smoothly though so it takes practice to guide it evenly. Once mastered it is great to ruffle on valances and cushion frills.
Other option is use a ruffler foot, these will make a little ruffle every 12, 6 or 1 stitch so give a set result, and to obtain a more dramatic gather. They look like this.
The arm of the foot with a C'shape sits over the needle bar of the machine so it is moved up and down to activate the device. The little blade at the front moves backwards at regular intervals forcing a "tuck" of fabric into the feed to be stitched. Again you can ruffle and stitch to straight fabric at once but it is an art to master.
The weight of the fabric you are gathering is obviously the key variable, ginghams and poplins are lightweight so gather easily but if you need to gather something heavy like cordoroy it is going to be a battle and threads may break. If so, stitch two lines of gathers and don't try to do long runs, you'll just break a thread and have to start over.
Another good way is to zig zag over a length of perle cotton, taking care not to actually stitch the pearle at all. You can then gather up the fabric along it, this works well for heavier weights.
Oct 22, 2011 | Janome Memory Craft 9000 Computerized...
I have the singer 7442 and i cannot figure out how to get the baste stitch for gathering material on a flower girls dress. I've tried everything and there's nothing in the manual, can you help with this?...
Normally to gather fabric, you select the regular straight stitch, turn the stitch length up to maximum (4 or 5 usually), and stitch two rows of stitches, one at 10mm from edge and one at 20mm from edge.
Then gather by pulling the bobbin threads (underneath ones) from each end to gather the fabric. If doing lengths of more than 1 metre, then stop, leave long thread tails, and start a fresh length of gathering threads to avoid gathering long lengths of thread which might break on you.
If your machine has a basting stitch it might look like " .___.___.___" on the dial however, I've never been that happy with machine basting for things like attaching slippery fabric to underlining, I've always done it with needle and thread to keep the two layers matching and not stretching/slipping. For example, stitching a piece of chiffon to a underlayer of satin, even pinning carefully, these two fabrics will slip under the machine foot so I'd always do it by hand.
If you have masses of fabric to gather, sometimes what is quicker is doing a large wide zig zag over a length of perle cotton (heavier than thread) at the 15mm seam, don't let the needle pierce the cotton though. Then you can gather the fabric along the perle cotton.
Sewing machine instruction manual often assumes a knowledge of sewing techniques that you may not yet have. I have the Vogue Book of Sewing on my shelf and refer to it often. Or Singer do a good range of sewing books too, its worth investing in a good reference book.
I also love, this is such an awesome website for dressmakers/sewing enthusiasts and you will find loads of helpful tips here.
Hope this helps you a little.
Apr 16, 2011 | Singer 7422
I have a Singer 6202 and the stitches stay tiny regardless of the stitch setting being set to gather. The machine is over 20 years old and makes a noise when I set it to gather mode. The reverse button...
check your needle to make sure it's not bent--take the needle & roll it on a flat surface to see if it rolls good
the feed dog help the fabric move -check your operation manual to see if the feeddog is in the proper positon-if it's in the proper postion
you might want the sewing machine check by a service technican
good luck
please rate this using the thumbs ,thank you
Aug 06, 2010 | Singer 7436 - INGENUITY
Sewing Machines Logo
69 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
