Question about Tablets & eReaders
Where is the reset button on this tablet because I tried button method and it doesn't work
  • 1,830 Answers
Where you plug in your tablet to have it charged. Hold and press it for 40 seconds.
Posted on May 13, 2017
How to hard reset prestige eliet visual land tablet
Hard Reset To hard reset your Visual Land Tablet, you need to follow the instructions below carefully.
1. Turn off the tablet.
2. Press and Hold Volume Up and Power button at the same time.
3. Keep holding the buttons till you see the start up screen.
4. Press Volume up five times when you see the android with an exclamation to reveal the recovery menu.
5. Since touch screen doesn`t work on this mode use Volume and down to move on the menu and power button to select.
6. Select Wipe Data/Factory Reset.
7. Select Yes- Delete all user data.
8. After the wiping select Reboot System Now.
Apr 01, 2017 | Tablets & eReaders
I dropped my tablet and now everything is backwards words,screen,everything help
Hello! you might need to calibrate your tablet`s sensor, if that doesn`t work please turn off the auto rotation on your tablet, and then reboot your tablet. if that doesn`t work, please do a factory reset on your tablet by pressing power button + volume down, your tablet will go into recovery mode and look for factory reset.
Jul 29, 2015 | Tablets & eReaders
My Premium 8 Nextbook tablet froze so I tried using the reset button in the back,that didnt work so I tried the hold the power button and volume at the same time method and that didnt work either...
Something must have happened during the last update. Either it lost connection or crashed before the process was complete. This unfortunately is called 'a brick' or 'bricked'. You will have to find a way to restore the OS to the tablet. It may need a complete wipe and reinstallation. My suggestion would be to find a local PC tech in the area that services tablets. Or you may have to contact the manufacturer and create a service ticket.
Apr 14, 2015 | Nextbook Premium 8 Se Android
How can I fix my tablet
First make sure the tablet is charged up. Sometimes you just need to hold the power button down a little longer. If that does not work, most have a reset button that is recessed on the bottom edge of the tablet. You may need to get out the manual for the tablet to find the reset.
Apr 08, 2015 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Steps to reset tablet which is stalling up again
hard reset in android tablet PC's
different keys have hard reset in android tablet PC's
u can try like this method
  • volume down + home button + power button
  • volume down + power button
  • volume up + menu + power button
  • volume up + power button
  • volume up + cam +power
  • volume up + lock button + power
Hope this helps !
Dec 19, 2014 | Tablets & eReaders
I forgot password on my RCA tablet. How can i reset it? I need a hard reset, how do I do that?
While it's turned off you hold the volume up and power buttons. Then when the android appears release the buttons. Hold the power button and press volume up. Navigate with the volume keys and select factory data reset. Hopefully this isn't the method you'd already tried.
Sep 15, 2014 | Tablets & eReaders
Won't load
Not a good sign, but not necessarily indicative of a dead tablet. Find the reset button (usually a pin/needle sized hole) and try that to reset. Alternatively, hold down the power button for 30 seconds, then release, wait at least 15 seconds, then hold it down for 3-5 seconds (normal start-up method). If neither works, post more info (did anything happen leading up to this behavior, how old is it, does it have any other issues, was it recently dropped, did you recently change to a different charger, etc.), and I'll try to help more.
Jul 18, 2014 | Polaroid 8 Internet Tablet Android 4.0...
Model:v705-s tablet pattern lock.so unlock the pattern
If you cannot unlock the tablet, look up the way to do a hard reset. You will lose all data, but it's one of your only options.
Usually the following method works:
1. Turn the tablet off.
2. Hold the volume down button.
3. Hold the power button.
This should boot you into your devices restore/update screen. If that combination does not work, volume up + power should.
4. Navigate to the wipe data/factory reset.
5. Wait for it to reload, and you're done.
Nov 21, 2013 | Tablets & eReaders
Tablets & eReaders Logo
62 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
