Question about RCA Televison & Video
I have RCA dvd combo, no sound I have checked sound settings ,tried HDMI or patch cords and still no sound. Tks for any help,,,RLEDB2556A is model
  • 211 Answers
SOURCE: sylvania 6720FDE combo tv/dvd/video
The codes for a combo set are found in the DVD settings or the VCR settings. Try the rca codes for DVD or Vcr and it should work. Although you may find that not all the functions will work properly ( ie: fast forward, open door, etc ). Good Luck
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
  • 2071 Answers
SOURCE: DVD no signal HDMI
Loose or crack or cold solder joint holding the socket of HDMI.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the TV turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If this solution help you understand the problem :rate as fixya..
Good luck;
Posted on Jul 16, 2008
  • 19396 Answers
SOURCE: No surround sound from my PS3 through the Onkyo 5100. Video OK
Go to settings on PS3 and sound settings and set them to HDMI.
If the above did not work, try a auto reset, with unit connected. Hold the PS3 power button down and wait until you hear 2 beeps. The PS3 will automatically search your input/output channels.
Posted on Jan 28, 2009
SOURCE: i have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Posted on May 09, 2009
  • 834 Answers
SOURCE: RCA tv dvd combo L26HD35D programming codes
not gonna happen
Posted on Sep 20, 2009
The yellow is video. Red and white are sound. If you are connecting a DVD you need to find INPUTS on your television. Depending on the age of your television and / or DVD, compatibility may be an issue. Try the internet for advice on your particular set as even some with HDMI inputs will only display picture and not sound. You could even ask at your local electronics store. Believe it or not, there are still some nice people out there. Not sure if this will help but good luck.
Jul 21, 2014 | Disney 13" TV
32 Inch rca lcd dvd combo has no sound?
Try vith headphones or audio out on the scart .
Try with audio standard in menu options.
try with signal on scart or hdmi input with other source of signal like dvd or cabel recivers.
If there are no sound after this you have to check-replace the audio section in your tv.
Jan 28, 2014 | RCA L32HD32D 32-Inch LCD/DVD Combo HDTV
I am having issues with my RCA Scenium D52W135D (playstation 3 connection). Recently, I have been having a very specific problem with this combo. I have it connected using HDMI to a Pioneer receiver...
Had the same problem. With mine the other day you probably moved your Playstation 3 too another tv and set your 1080i,720,480 to high deaf on settings in Playstation. You have to change them back to automatic that TV says HDTV but it only plays Playstation 3 on 480 checked in settings of Playstation. Played mine for 4 years on that TV moved and got a 3d wifi then dad got him one And was going to trash that RCA but I told him I would take it for now too keep from buying another TV at this time got it in my new home wouldn't play video but it. would sound tried different cables but still now change. But remembered i changed all of my settings over when I got 3D TV. Playstation 3 hadn't been on know other TV. Since I owned it but that RCA now won't work then came to me last night and playing it on both TVs but you have to change the settings on it before moving it or you cant see the screen to fix it do that guarantee it will fix it. Like you said everything else works PS 1,PS 2,DVD, cable,but PS 3 won't its the settings in theme,and audio.
Nov 10, 2012 | RCA D52W135D 52 in. TV/DVD Combo
How can I change the subtitle settings on the TV? They set fine through the DVD settings but then don't appear on the TV screen. Thanks for your help.
Hi Wendy,
May I know what cord are you using to connect your DVD player to the TV, is it through the HDMI or RCA? Let me know to assist you further.
Apr 05, 2011 | Sharp LC19DV27UT 18.5 in. LCD TV/DVD Combo
How can I connect my vhs player to my insignia tv? It already has a built in DVD player? I've tried the tri color cords but they don't work.
I would need to know the model number of your TV to be sure. But the RCA plugs should work (tri-colored cords... Red, White, Yellow typically) But if it's a combo TV/DVD player... you probably need to change the input to AUX1 or whatever the tri-colored RCA jacks are plugged into... and not on DVD setting. Try that. and advise back!
Oct 12, 2010 | Insignia Televison & Video
Hi, Just bought a 26" sony bravia tv. I don't use cable or satillite. I just need to find out what kind of cable I need to connect my panasonic DVD player to the TV and which port do I plug it into?
The best quality would be a HDMI cable, if your DVD player has a HDMI port on the back.
Any of the HDMI ports on the TV can be configured to take the audio over HDMI (digital audio) or over a separate rca stereo patch cable (menu option in the TV for analog audio).
So if your DVD has HDMI, just buy a HDMI cable and you're done. If you cannot figure out how to switch the audio input, there is no big harm in just installing a separate RCA patch cable between the two for the sound.
The next-best would be a component-video cable (Red/Yellow/Green) RCA cable, with a separate red/white RCA audio cable.
Alternately, if your DVD has a S-video port, that is comparable to component video. Then you would need a separate audio cable as well.
Last but not least, if your DVD player is ancient, it may only have a yellow video out connection, then red/white for audio. You then just need a standard yellow/red/white RCA component cable.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Flat screen to dvd connection help!
It depends on the TV.
On my Phillips TV this is switchable via the TV setup menu, and you get no sound with HDMI unless you change that setting.
The reason it's switchable is that the HDMI input is usually common with one of the component-video inputs (AV3 on mine). (cost saving move)
Thus if the menu is set to hdmi, then the audio goes thru hdmi. If it's set to 'component' then it goes thru the RCA patch cable.
Oct 07, 2009 | Televison & Video
I have recently acquired a digital TV. Additional connections are pay TV and vcr/dvd combo. The TV and pay TV are working but I am unable to access DVD/VCR Combo on either AV1 or AV2. The combo is...
just trace one source at a time you will be able to find the problem. take note: IN goes to OUT and OUT goes to IN ...this goes for video and sound
Aug 17, 2009 | Televison & Video
Magnavox zv427mg9 sound problem - VCR/DVD combo connected to a Vizio VW42LFHD TV. After some playing around we got the DVD running OK. We can see video and hear the audio. However, the VCR does not play...
sr you can disconect hdmi cable and use a litle speaker and check for audio in rca cables output , when you put your vcr play you can have audio in rca red cable and rca white cable i think when you put hdmi your loose in rca the audio , remember in hdmi you have audio and video , if you dont have audio in vcr the audio head are bad thias is used only in vcr mode. good luck
Jul 08, 2009 | Televison & Video
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
Jan 24, 2009 | Onkyo Audio Players & Recorders
Televison & Video Logo
32 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
