Duraflame remote control - Heating & Cooling
Turns on for 1 minute and gets Er - I cleaned filter
It may be getting too hot and activating the safety shut off. This may need a new board. I have never worked on one of these but it has to be fixable. Depending on the cost of the unit as to whether or not it is worth it.
Mar 04, 2016 | Duraflame Powerheat 1500W Infrared Quartz...
My Duraflame heater keeps coming on by itself
try to remove the battery of the remote, also try to replace the battery with new
Oct 04, 2015 | Heating & Cooling
What does it mean when my heater says er
It means there is something wrong with the heater or the controller fro the heater.
Oct 05, 2014 | Duraflame 1500 Watt Heater-Fan with...
Not working
There is a thermostat on the unit. it is probably set too low.
So the heater quickly hits the low temperature and shuts the heat off, then when the temp drop it will come back on.
Feb 15, 2014 | Duraflame L Electric Stove with Remote
Furnace will not turn on from remote or furnace
Is it a residential furnace with a thermostat on a wall some where? Are you sure its power is on?
Nov 13, 2013 | Duraflame Heating & Cooling
MY DURAFLAME HEATER COMES ON BUT ONLY BLOWING OUT COLD AIR?
Sounds like something in the control module. I have 2. One bought used about a year old. Lasted about 3 months and something in the control module or panel died so would not light or power up. I hard wired the blower and Infrared bulbs to manual switches so I can manually turn on and off heat. Have separate switches so can leave the fan blowing after turning off the elements to allow them to cool. The other heater was bought new and laster about a year and a half. Then the thermostat reading worked and fan worked cycling as should but elements would not light. Did a factory reset holding power button while plugging in. That fixed it for a day then back to same. took back off and while trying to trouble shoot voltages on the power supply module the elements started working again. Not sure what the issue but seems to be a definite issue with short lived control modules. To date have not found a resource to buy new control boards or other replacement parts besides bulbs which with the fans seem to be the most durable part of the whole heater.
Feb 20, 2013 | Duraflame Heating & Cooling
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
