Question about Golf
I have a E-ZGO2five and my automatic emergency has locked up and how can I release it?
I have a E-ZGo -2five SUV and the automatic emergency brake has locked up. How do you unlock it. Jerome
try rocking it back ,and fourth .That may release it does it release when you put it in gear normally, or do you release it manually? If manual, look for springs that pull cable back when you release it, if it releases when put into gear look where lever releases cable. If unit has sat for awhile rust may have frozen brake parts...rocking may release it.
May 14, 2017 | Cars & Trucks
Automatic shift stuck park
flat towed, in park is not possible
the shift console, has an emergency park lockout, release feature
what is broken, unsaid.??????
the lost operators guide covers both towing rules
and shows that emerg. button location. use it and shift the shifter to neutral.
the front wheels are locked in park.
the problem with flat towing any car are many.
steering lock failure. (locks in motion)
transmission oiling , when the engine is not running the
transmission pump is dead, and oil lube is lacking to many critical areas..
page 163 here covers, the magic switch (emg)
page 160 is tow.
no flat towing.
it can be towed on its rear wheels all day long.
the transmission issues, can be very serious.
do no listen to some dweeb saying gee i towed min 500 miles the wrong way, do not. he never rebuilt a transmission in his life and dont understand how it works deep inside.
page 161,
Never tow a vehicle with an automatic
transmission from the rear with the
front wheels on the ground, as this
may cause serious damage to the
page 162, emergancy towed with chains (flat)
short distance with a driver in the seat
in neutral. , ACC position at key switch.
obviously if the key switch parts, are bad, this dont work and would be
very dangerous to all person, in car, towing, and me on the road.
Feb 03, 2014 | Toyota Corolla Cars & Trucks
Where is the emergency trunk release on 1992 merceds benz 300e
Are you asking for the release if you are locked in the trunk or is battery is dead, not sure what emergency release you are asking about for the trunk, if it is the one inside trunk if you are locked inside then this year does not have one
Oct 01, 2012 | Mercedes-Benz 300-Class Cars & Trucks
When my car starts the Headlights come on automatic, But now they are not coming on
check your emegency brake to insure that is is off. pull the emergency brake release to insure the e-brakes released. you may need to pull the e-brake handle and at same time handle is pulled,w/left foot lift up on the e-brake pedal.the headlights[or running lights] come on automatic when the cars running,unless!!! the emergency brake is on.if the emergency brake is on,the headlights,or running lights will not work. check this please! thank you for choosing!
May 02, 2011 | Mercury Sable Cars & Trucks
Door will not open. Have tried emergency lock release on p. 29. Still does not open. Have unplugged for 1 hr. Does not open.
emergency lock as in the release mechanism inside the access door on the lower right corner of the face of the washer? try pushing in on the door with force will doing this
Jan 20, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
In any vehicle exist Automatic hand brake Release?
There is no automatic hand or emergency brake release that I am aware of. That would defeat the purpose of the Hand or Emergency Brake.
Jun 26, 2010 | 2007 Mercedes-Benz C230 Sedan
Motorola F3c handset is showing ' locked 1-100' on the screen. No other buttons work except for emergency calls. How do I release this lock?
motorola F3c handset is showing ' locked 1-100' on the screen. No other buttons work except for emergency calls. How do I release this lock?
Oct 26, 2009 | Cell Phones
How do I realease the emergency brake. I have a cadi deville 1997?
up by the emergency brake mechanism the is a small black unmarked lever....pull it and it will release.
I am taking it that the automatic release is not working?
Sep 11, 2009 | 1997 Cadillac DeVille
I can't get my convertible top to go up or down, it is stuck half way. Is there a manual release for it?
The convertible top motor and release lever are in the luggage compartment.
From the Bentley manual, the following general procedure is suggested in order to close the top in an emergency situation.
Main motor. To release the top linkage from the motor, lift the left corner of the rear seat to access emergency release handle.
It is then possible to push the top manually to a near closed position. In case of the semi-automatic top, simply attach and lock the front latches.
Front latches. Once the fully automatic convertible top has been released from the motor and manually pushed to near-closure, emergency latching of the top is possible by using the S-shaped hex key provided in the emergency tool kit(attached to the trunk lid underside).
First, remove the the plastic cover over the latch motor in the front bow of the convertible top.
Next, use the hex key from the tool box to crank the front latches shut.
May 12, 2009 | 1999 BMW 323 Series
Golf Logo
48 people viewed this question
Top Golf Experts
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
